26M Steaming light deck fitting
Semper Fi
Post by Semper Fi »
I have been having trouble with the stock (perko) steaming light deck fitting on my 2006 26M. I have replaced it twice. It starts out as bad connections that you have to wiggle so the light will work. Then the small pin eventually breaks off rendering the connection useless. I have searched the forum but did not find if anyone else is having this trouble and if a suitable replacement was found.
Québec 1
Re: 26M Steaming light deck fitting
Post by Québec 1 »
We all have that problem. I sanded the 2 pins and put electric oil stuff in the little holes on the deck and repeated every season.
Q1
Love MACs
Post by Love MACs »
Mine is shot also :? The PO has taped and retaped the pug and it is literally falling apart. I hope someone here knows of a plug to replace it :!:
Allan
waternwaves
Post by waternwaves »
I picked up my replacement plug at WESTMArine
Post by K9Kampers »
I've been thru the same repair a few times, eventually repalcing the split two prong plug with a solid four prong plug. The four prongs allow for two seperate light circuits, plus the new plug has a threaded collar for a solid tight connection. After only one season with this plug, nothing adverse to report yet.
c130king
Post by c130king »
I also had to replace the plug...bought the new one at West Marine. The deck mounted receptacle is fine...just the plug pins broke.
trip01
Post by trip01 »
Post by K9Kampers »
I'll see your two prongs, and raise you...two prongs!
FLembo18
Post by FLembo18 »
Andy, nice 4 prong, where did you get it ?
Post by K9Kampers »
Bluecrab
Post by Bluecrab »
I purchased the same 4 prong from WM but could not get 4 wires with casing through the strain relief hole, very small.
I found this 5 pin one and ordered it. I have it but have not installed it yet. With 5 pins I plan to add anchor, spreader, and deck lights to the mast.
http://www.aquasignal.info/ecat/htdocs/ ... tem_id=645
Wally
Post by K9Kampers »
Bluecrab wrote:I purchased the same 4 prong from WM but could not get 4 wires with casing through the strain relief hole, very small.
Yeah, for that little rubber grommet...silicone spray & determination!
Semper Fi
Post by Semper Fi »
My intentions as well. Where did you get it?
Wally
Bluecrab
Post by Bluecrab »
Semper Fi wrote:My intentions as well. Where did you get it?
http://www.defender.com/productsearchresult.jsp
Wally
