I just have to tell this story
Yesterday the weather was nice enough to remove the tarps from Nice Aft, and start the Spring cleaning. After I had removed both tarps, and had them folded on the driveway, I just stood there figuring out what I should do next. I then heard several beeps of a truck horn, and turned to see what was going on. I saw a dodge pick up truck, but I had to put my glasses on to see clearly. A fellow in the truck was just sitting there at the intersection, with his hand out the window whiles giving a thumbs up sign and yelled out his window, "every time I see your boat, my head takes me somewhere else."Image
I told him, me too :!:
Five years spending the Winter in my driveway, and it still gets commentsImage
Thanks Roger,
Matt19020
Re: I just have to tell this story
Post by Matt19020 »
Ray,
I just took my cover off also I just have some cleaning and waxing to do. I may even try Poliglo or something like it on my black stripes. I hope to be in the water by the weekend of April 10th.... with any luck.....
Trouts Dream
Post by Trouts Dream »
About 9 weeks to go here. :cry:
Doug W
Post by Doug W »
It was 70 degrees (f) here Friday afternoon!!! I pulled Galactica out of her barn to see sunshine and plan adventures! :D :P :D
Glad I put her back. We got 6 inches of snow today....and it's sleeting out now... :?
pokerrick1
Sailboat: Venture 23
Post by pokerrick1 »
Nice looking boat, Doug - - - but I'd MOVE if I were you 8)
Rick :( :macm: Less
Yep worked on my boat on Fri +20C , said to myself na to early yet to bring her out of the shop,. and Sat -0 C & snowing :x Only in Canada you say ! Oh well spring is here wont be long now :)
Highlander wrote:Yep worked on my boat on Fri +20C , said to myself na to early yet to bring her out of the shop,. and Sat -0 C & snowing :x Only in Canada you say ! Oh well spring is here wont be long now :)
Went out to the boat today to reinstall my galley. 60sF (same as you) sunny and warm. It was actually warm to work on it. Tonight they are forecasting 2-6" of snow. Only in Canada? Nope.
dvideohd
Location: Richardson, TX; Galveston, TX; Dana Point, CA
Post by dvideohd »
Texas, too....
6" of snow on the ground this morning.... (Dallas...)
Love MACs
Post by Love MACs »
Beautiful day here yesterday also. :) Worked on the boat and installed my Quick Release Rudder Cleats, finished my velcro along the hatch opening and messed with LED interior lights but that is another story/mystery/issue that has since been solved. Wanted to get to the boat to test my water line connections after completing my pump and new galley/head line install....but has been raining like hull since last night :!: :( No snow but more than enough rain. Tomorrow is forecast the same :( :(
Allan
Chinook
Post by Chinook »
NiceAft wrote: I then heard several beeps of a truck horn, and turned to see what was going on. I saw a dodge pick up truck, but I had to put my glasses on to see clearly. A fellow in the truck was just sitting there at the intersection, with his hand out the window whiles giving a thumbs up sign and yelled out his window, "every time I see your boat, my head takes me somewhere else."
My wife and I have had frequent similar experiences and reactions. We've taken to calling it "the look". It can occur when we're towing it through a small town or, like you, when cleaning the boat in the driveway. I got a different reaction when I had raised the mast in the driveway, and unfurled the genoa, so I could replace the nylon furler bearing with a stainless steel ball bearing. My neighbor, a life long logger, wandered over and drawled "I thought you needed water to sail those things in." :)
Rick Westlake
Post by Rick Westlake »
Mike, that's a howl! Goes to show that you don't have to be in Vermont to be exposed to "pawky Vermont humor."
Bossa Nova's in a storage facility two miles from my townhouse, for re-fitting season. I've had the mast up a few times. One time, I'd been working on where I might put an inner forestay - just before some of our heavy weather of this winter - and one guy came past my parking space in his truck and yelled, "You expecting it to rain THAT hard?!"
delevi
Post by delevi »
What's a boat cover? 8)
Sorry, couldn't resist. Can't use my boat now, even though the weather is amazing. Not sure what's worse.
I will tell you, since you don't know........
Having the boat, nice sailing weather, and not being able to use it cause its motor is U/S.
We have to put ours away for 6 months, we just accept that as SOP due to our locale.
Put it away and try to forget about it for 6 months.
Then its play time come May.
8)
Get the 115
Its only money
Chinook wrote:I got a different reaction when I had raised the mast in the driveway, and unfurled the genoa, so I could replace the nylon furler bearing with a stainless steel ball bearing. My neighbor, a life long logger, wandered over and drawled "I thought you needed water to sail those things in." :)
Heh,
I remember when I raised the mast in the driveway, my neighbor stopped his Hummer in the middle of the street and just stared at it. When I came over he just said, "Wow.....(long delay)...wow!"
