I wanted to share what I think was a significant speed improvement. For a large portion of the race, we had very light winds that were coming from directly behind. We also had two Mac26M's configured pretty much identically. Mine had the main, 150% Genoa and cruising spinnaker. Mark's had main, 100% jib and cruising spinnaker. At the time, we were both running spinnakers and mains only (no fore sails)... sometimes, wing-on-wing, sometimes not. We were running around 4.3 knots (gps). We were side by side for several miles with no clear advantage being had by either.
I found it tedious. There was a very fine sweet spot for keeping the spinnaker from collapsing and the boat was not totally balanced thus requiring constant attention at the helm while watching the cassette tape tail tells on the shrouds. I could more easily see on Mark's spinnaker the the ripples forming and start losing the edge.
With the main on the same side as the spinnaker, it clearly blocked much of the flow to the spinnaker. Even wing-on-wing, the wind shedding off the mast side seemed to cause a lot of turbulence into the spinnaker. In my opinion, the main can't be set up great for down wind because of swept back shrouds even with a boom-vang and it was also hurting the spinnaker's efficiency.
So here is what we did...
(1) Lowered the main (Mark starts taking the lead)
(2) Whisker pole out the Genoa win-ward. Unfortunately, I broke my homemade one earlier in the day... so I did the following instead.
(2a) Ran the win-ward, Genoa sheet through the ring on the end of the boom.
(2b) Removed the topping lift to let the boom fall.
(2c) Mounted the lower end of the boom-vang on the ring used for the mast raiser's side line.
BTW: This works great when wing-on-wing also. It allows you to both crank down on the main to keep it out of the shrouds and as a preventer to keep from the boom to the windward.
(3) Pulled the Genoa out (furled) via the sheet through the boom's end eye.
The net result was wing-on-wing with the Genoa and spinnaker, with no main to cause turbulence into the fore sail and spinnaker. The spinnaker filled and stayed filled. I believe the Genoa actually helped fill the Spinnaker. We found the setup to be entirely balanced and having a large angle sweet spot. We quickly regained the half-mile lead Mark had opened up while dinking around and passed on by. We were running around 5.5 knots (gps), but I don't know how much of that was improvements or wind speed change. We were decidedly faster.
It would work far better and faster to set up with a whisker pole since you could get the sail out further than the boom's length.
Anyway, I hope someone wins a race using the technique.
