http://www.youtube.com/watch?feature=re ... pw2E&gl=US
http://www.youtube.com/watch?v=ZdVHhg5600Y&feature=fvw
Does anyone know of any similar tests on a Mac?
Except Mac X/Ms can go very fast.Lloyd Franks wrote:Not sure what the purpose is...Sailboats aren't very fast, and unless you hit a pier or a dock, most collisions would be with another floating object. And because of the hull shape, most encounters would be glancing...
waternwaves wrote:When mac's are going fast, lets say twice the speed of that dehler.......
they travel right over obstructions like that and take out the lower unit on the outboard.
or at worst, put a hole in the ballast tank, with only a few inches of centerboard down when powering at high speeds, an X boat CB will probably kick up,, an m boat...........????
I've often wondered....
Ive often wondered, if dagger boards are such an improvement, why not make the M boat rudders dagger style instead of swing style???
enquiring minds.
If that means eliminating the slop and a stronger bracket setup, I'm all for it, especially if such a setup would hold up to larger rudders. Personally, I think the kick-up rudder system is a "less than seaworthy" arrangement. One of the weakest links on the boat IMHO. In fact, and I've been on this soapbox in the past, the fins on both Macwhy not make the M boat rudders dagger style instead of swing style???
Motoring at high speeds, all fins should be up, so unless one is careless, it shouldn't be an issue. I ran aground a couple times while under sail with my heavy duty DB. No issues so far. Stock board may have snapped. Both times were mud. Nothing solid, fortunately. The DB trunk is supposed to be able to take quite a bit of punishment... so I'm told.or at worst, put a hole in the ballast tank, with only a few inches of centerboard down when powering at high speeds, an X boat CB will probably kick up,, an m boat...........????
