Garmin 441s. Need some help on installation
- BNG
I just installed Garmin 441S on my mac 26x . The depth is not registering on the display. Im folating in about 18" of water and no numbers are showing up just two dashes --. All cables are connect and GPS works. also, what method do you use to route the wires inside the pedestal . Maybe I didnt program something right but I was hoping to get this running by this weekend. Thanks Brian
- jcasale
Re: Garmin 441s. Need some help on installation
Brian
Can we have a little more info on your set up? Where is your transducer mounted and does Garmin specify a limit to that units resolution or ability to give accurate readings at such a shallow depth?
John
2010 Jacksonville Macgregor Get-Together
John
- BNG
The transducer is transom mounted. I just dont understand why its not reading.
Okay... great news. Now share the solution for future Garmin users.BNG wrote:problem solved
- BNG
I reconnected and connected the tranducer plug and reset the factory default settings. Restored the power and it started working. I'm not sure really what happened, but its working now.
- Love MACs
Welcome to my world.
That is exactly what I did to my old 162 and presto
Back to its old self again. There is also a setting with in the System's tab that allows you to set water depth reading...but u probably already knew that
Allan
Allan
