Any ideas of how to keep the
Thanks
Singlehanding it's safer to stay off the deck. I used to scramble forward to raise the main when I singlehanded.Lazyjacks & lines led aft can make it easier and safer while singlehanding. That said, I don't have either on my, and still go up on deck when singlehanding. Organization, speed, and agility are what I rely on.
This works for me, too. Standing in front of the console, it's easy to reach back and correct course if the boat starts to drift off the wind while you're hoisting the main. It also helps to keep the mainsheet uncleated while you hoist so you don't start sailing prematurely.argonaut wrote:Leading the main halyard to the cockpit is about the most worthwile project I can imagine.
Now I simply slow the motor, head into the wind, pull the main halyard line through the clutch I bolted onto the cabin, let out some jib, point down wind, switch off and raise the motor and I'm sailing. I can do all that seated a little forward of the console in the cockpit.
An autopilot is an enormous help for keeping thegriffin40m wrote:Hello,
Any ideas of how to keep theinto the wind and to give you time to hoist the main sail single handed?
Thanks
Raise the Jib. Bring it in just enough to move the boat. That will keep the boat pointing close enough for the main.griffin40m wrote:Hello,
A habit of mine since forever is to start the motor before dropping canvas. If something goes wrong I've got a backup to get me out of trouble. This goes against all the "pure" sailors I've met. One in our marina insists on sailing into the slip and dropping just before. Seems silly to me.WHRoeder wrote: For dousing, I heave to, drop main, go on top and secure cover, etc. Finally start engine and furl.
There is something queer in the sailing community that breeds people like this - Ive not quite come across this in any other endeavour to the degree that I do in sailing circles.ne in our marina insists on sailing into the slip and dropping just before
