We anchor out quite often and the first thing I noticed about the boat , is there is no way to " light that can be seen all around " , as the rules states .
You can turn on the masthead light , but that doesn't cover the stern . if you turn on the stern white light , you also turn on the Nav lights , which is agaisnt the rules for an anchored boat .
Untill now , we have hung a LED lantern in the rigging , and mounted some LED solar lights in the stern.
Part of my rewiring is to put the stern white light on its own switch , so I can turn on the mast light and stern light , and leave off the red/green Nav lights . This should satisfy the law . Of course I will also use the solar lights and whatever else , as their is no such thing as to much light when you are anchored.
What does everyone else do ?
Did Mac change this in later models ?
