So my guess/estimate was close . About 1/2 or better the effiency of a generator . But factor the $1,000 for a generator , and all the inconvience of them , and you come out about the same .Catigale wrote:On outboard vs generator fuel consumption - I make it the HONDA gen would be 2x efficient or less.....based on:
1. Charge curve for Mercury BF
his is an old thread but I found my Merc 50 HP Bigfoot manual with the following alternator charge curve - the charge curve is highly asymptotic as given by the following table
RPM output in Amps
Idle 0
800 8
1000 12
1500 16
2000 18
3000 19
>> Use 1500 rpm, 12 V * 16 Amps - 6 amps overhead means 120 Watts charging capacity....
2. ...From JamesV smartcraft data, he reports
I have the Mer 50hp Bigfoot 4 stroke, 14 x 10 prop. Not quite yours but it might help
5 mph - 12 to 16 mpg
or about 2.5-3 hours per gallon fuel burn under load. You could probably put 220 Watt-hours of charge into your batteries per gallon of gas this way. The HONDA EU1000 is rated at about 1/2 of this fuel consumption. The Mercury might even be close to this just under alternator load.
The gas mileage would be a hard one to figure . I average better than 10mpg at 2,000 rpm , if I idle her at 1500 rpm with no load that would have to equate to around 20mpg or better (another guess/estimate)
