Ixneigh wrote:I keep Shoal on a three anchor mooring system. ....Idneigh
Hey we are in Sunset Cove off Key Largo at the moment and for at least tonight, where are you?
We use an......
..... anchor sail that Ruth made from a Sailrite kit most nights, and have it up right now.
http://purplesagetradingpost.com/sumner ... vas-5.html
If you read the link above you will see that I had a couple reservations about it after using it last Fall.
On this trip I set it up so that it is.......
... just above the solar panels. Above is how it was, now it is down further on the backstay to where the two arrows are in the picture by the solar panels.
It ties off forward at the bottom of the starboard stanchion at the cabin/cockpit bulkhead instead of at the bottom of the next stanchion forward like in the pictures in the link above.. There is no more banging around unless the winds are over 25-30 and even then it is not bad. Also now the line too it is behind the pop-top and not next to it. It also seems to be working with its center of effort a little lower and further back. The boat sails way less on anchor than without it.
Now keep in mind that we have a S which helps some also. As I mentioned above we use it about every night and also used it on the mooring ball in Boot Key Harbor at Marathon with good results.
c ya from Key Largo,
Sum and Ruth
Our MacGregor S Pages
Mac-Venture Links
