Thanks for the suggestions.Hardcrab wrote:It's maybe a goofy idea, but is it possible that the center hub has a loose or worn rubber insert piece and the shaft torque is just not being fully coupled to the prop and is slipping?
I know the standard story for this symptom is "in gear, engine running fine, but I'm not going anywhere".
Not the case here but it sounds close to it, kinda, sorta perhaps.
But then again, maybe this outboard uses a regular shear pin type design to couple the torque to the prop?
This outboard uses a splined shaft with a castle nut to couple the prop to the hub. The michigan wheel prop I have uses a hard polyurethane type material in the hub to cushion the load on the lower unit as well as make the same prop fit multiple outboards (I'm guessing). I checked the hub and it does not seem to be slipping (It better not since it's brand spaking new!) I'm thinking that maybe this "universal" prop for multiple outboards design is causing problems with my outboard. It seems that some other people have used the same prop with some success (Over 7 mph), but I'm wondering if the skeg might be too close to the prop's leading edge (see pics above) causing cavitation/ ventilation issues. I noticed in Ross's pic the actual blades are much farther away from the skeg, but that could also be because of my shallow pitch is 9" vs his 12".
The outboard seems to be at the right height with regards to the cavitation plate and the bottom of the hull, but I will try to lower it to the last hole.
