Had issues with the keel not dropping, not sure if its wedged or what? Thinking of taking a small bar with next outing to see if I can tap it loose from above...
Also trying to figure out the winches on the sides of the boat, as well as some hoops and such, it appears that its set for rigging to run through, but I am thinking its for the genoa? You can see the drum winches and such along the sides, there are also rope channels on either side along the companionway hatch....
have scraped, wiped with bleach water, and repainted the interior:
before:
After:
Have cut out a sewn 2 of the cushion covers so far. I have to make one of the bow cushions, was missing the starboard side. I am also using a Canvas Duck material, thinking of breathability and ease of drying should they get wet, will post pics asap..
Does anyone have a good pic or manual or something that will give me a good view of a fully rigged V-21? I have seeen a copy of the manual thats (I think) the original manual or info packet, but I was looking for details....
There is also a plywood disc mounted to starboard of the companionway door, any idea what was originally mounted there?
Thanks!
Wes
