Discolouration on coach roof & cockpit floor
robbiebull
Has anyone come across rust discolouration on the coach roof or cockpit floor, I have a 2000 Mac 26X, I have tried to polish them out to no avail
- bscott
Re: Discolouration on coach roof & cockpit floor
Try CLR. I also use white wall tire cleaner on the black spots.
Bob
Bob
robbiebull
Borax, you will need to elaborate ?
CLR, again I must be slow this week
- RobertB
Rust stains probably need to be removed with a iron/rust removal product - suggest using IronOut. This is a weak acid, uses include cleaning the resin bed in my house water softener - leads me to believe that if careful and wax afterward, should be OK with fiberglass.
- nedmiller
Leaves and such that might spend some time on your boat may leave some brown staining--our oak trees leave a dark and difficult to remove stain due to tannin. We use Chlorox Clean up--which is a cleaner that has bleach in it. It works really well. Make sure the boat is in the shade on a cool day or morning... spray on and let sit for a while before washing with high pressure. I use a gas powered water blaster. (Keep chlorine products away from electrical connections and electronics.)
SILK
SILK
Default User
I bought some 20 Mule team Borax last night based on your testimony!mastreb wrote:Sounds like a job for Borax
