I moved the original axle 18 inches forward, added the second 36 inches behind.
Fenders are all aluminium: Had custom supports bent to get the right angle against the fender and added a middle support with two large angles and a straight bar.
All hardware is stainless steel - even the trailing arm bolts (replaced the stock galvanized ones and greased the splines so corrosion will not totally lock-up and prevent disassembly).
Used a small dock edge protector along the top edge to keep the hull from hitting the fender. Now to remove the black marks the stock fender left on my hull
Fortunately, was able to do mod with the boat on the trailer - after I figured out the boat does not rest on the axle cradle if the boat is all the way forward on the trailer and supported at the rear crossmember - had to purchase a right angle air drill to drill holes for the bunk outboard support in the top of the trailer i-beam.
Have yet to try it out since the tarps are up for the winter.
UPDATE: Checked MD State regulations about brakes - must have brakes on all wheels of a single axle for gross trailer weight of 3,000 to 10,000 pounds. So, having brakes on only the front axle appears to be legal.
