ETEC-60 Tilt Lock Issues?
FAAbaddog
Location: Pensacola Beach, FL "FINS-UP" 2011 26M E-TEC 60
Post by FAAbaddog »
All,
My 2011 ETEC-60 was recently taken to my local 'rude" dealer here in Pensacola, FL...I asked to have the tilt lock repaired as it will not rotate at all... :o
I assumed under warranty right? WRONG, factory does not cover according to round one with the local "rude" shop so I am out $200+ for the bill... :?
WTF, any suggestions would be greatly appreciated as I believe this to be a systemic issue with all lower HP ETECs... :x
Thanks!
Respectfully,
BADDOG :macm:
RobertB
Re: ETEC-60 Tilt Lock Issues?
Post by RobertB »
Spend another $100 for the factory repair manual. I buy these for every vehicle I own and they always pay off relatively quickly.
C Striker
Post by C Striker »
I have the same motor and use a rubber mallet to move that dang thing. It's not for trailoring, but a 2x4 doesn't like to stay in place.
What I need to do is take that rubber mallet and shape it into a nice form fitting shock for hitting the highways. The list continues... :(
C Striker
Post by C Striker »
Hey any other E-tek guys happen to know the spark plug gap? I have the shop book but its not in there. the list continues... :(
FAAbaddog
Post by FAAbaddog »
sounds to me as if this is a common problem, yet the BRP factory turns a blind eye....really?
grrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrr.... :evil:
BADDOG :macm:
jbousquin
Location: Sacramento, CA 2011 MacGregor 26M 60HP ETEC "The Nauti Neighbor"
Post by jbousquin »
Sorry for cluelessness, but what is the tilt lock?
Are you referring to the metal tab that you swing down to hold the motor up and take pressure off the hydraulics once it's in the up, or tilted, position?
I ask because I have the 2011 60 HP ETEC as well, haven't noticed a problem. But I'm primarily in fresh water.
Joe
March
Post by March »
The metal ear to hold the engine up is a joke: try lowering the engine with the ear in place, and the metal tab will promptly bend.
I have been using a piece of styrofoam. I lower the engine, press the piece into shape, and discard it when it starts to crumble.
C Striker
Post by C Striker »
Thanks for the tip, I'll try that and cover it with duct tape.
FAAbaddog
Post by FAAbaddog »
All,
Upon further pressure, the tilt-lock was replaced free of charge under warranty....wooohoooo! :D
BADDOG :macm:
kitcat
Post by kitcat »
Good news, but it is so annoying that you have to push suppliers all the time!
Interestingly, I had a similar or the same problem, with my '09 Etec 60, in that the support just would not move, I eventually moved it with the help of a large hammer and a block of wood, but it was always stiff. I didn't need it very often because the boat is kept in the water all summer, but this year I tried it a couple of weeks ago, and it was easy to move by hand. I do not know why it decided to free itself off. Odd!
Paul.
