Access Plugs for desk hardware bolts
MarkSouth
Post by MarkSouth »
In the picture you will see 2 "plugs" which give access to the bolts for the winch and the cam cleat. I am going to be moving the cam cleat so will need to get more of these plugs. I guess I am searching for the wrong thing as I wasn't able to find them on google. :wink:
So what is the proper way to get to the backside of the desk fitting like this winch and cam cleat? Is there something else available?
DaveB
Re: Access Plugs for desk hardware bolts
Post by DaveB »
Blue Waters Yachts has them.
MarkSouth wrote:In the picture you will see 2 "plugs" which give access to the bolts for the winch and the cam cleat. I am going to be moving the cam cleat so will need to get more of these plugs. I guess I am searching for the wrong thing as I wasn't able to find them on google. :wink:
MarkSouth
Post by MarkSouth »
Do you know what they are called? Are they "access plugs" or ?
u12fly
Post by u12fly »
Yup BWY carries them, you can also get them at lowes they typically stock the smaller ones. They are typically called plastic hole plugs and available in white or black. They are identical to the ones used in the interior on my :macm:. As far as access goes, I do not have any holes in the outside of my boat, I have accessed everything by cutting holes in the interior of the boat and making nice close out panels of wood or in some cases fibre glass and finish like new (takes a bit more work, to blend and hide the repair)
Chris.
MarkSouth
Post by MarkSouth »
What department at Lowes has them? Like the painting dept or ?
RobertB
Post by RobertB »
Hardware dept - look for the drawers of specialty hardware.
DaveB
Post by DaveB »
http://www.bwyachts.com/BWYParts/PartsList.htm
MarkSouth wrote:Do you know what they are called? Are they "access plugs" or ?
MarkSouth
Post by MarkSouth »
I tried the bwyachts web and get 0 results. I guess I am doing something wrong.
I did find something that I THINK is correct at Grainger.com, ordered and will see if they are right.
I also sent bwyachts an email so hope they can help if Grainger doesn't work out.
thanks for the help!
DaveB
Post by DaveB »
All you had to do is click on the link, would take you to the plugs.2inch plugs costs .75 cents each.
MarkSouth wrote:I tried the bwyachts web and get 0 results. I guess I am doing something wrong.
MarkSouth
Post by MarkSouth »
I found out its a problem with Safari on my MAC ;)
WIll try on my windows computer now...
thanks!
BWY parts site doesn't work with IPAD either... Cheryl...you might want to think about that on next rev... :)
dr_soarus
Post by dr_soarus »
The BWY parts area works well with Firefox browser on Macs.
Phil M
Post by Phil M »
You cannot use Firefox on an IPad, unfortunately. :(
It is a drawback if you like Firefox, like I do.
I used deck plates they are water tight come in 3" dia. & up just screw off the lid & u have access these plastic plugs are prone to getting pulled out & they are not water tight
Plus the deck plates allow u alot more access
PS here's my set-up
http://i844.photobucket.com/albums/ab1/ ... 10/003.jpg
