RobertB wrote:Your straight bunks will yield only one point of contact with the hull on each side. They would work for a pontoon boat but I cannot see how you are going to support and hold in place a rounded hull. If you are not goint to use the rollers, then I suggest you copy the cradle arrangement of the stock trailer.
BTW, I talked with Mike I at Macgregor yesterday about hull thickness. He stated that these boats (at least my) have a hull thickness below the stripe of around 1/2 inch of solid fiberglass. This keeps the hull from developing flat spots when they sit on hard spots on the trailers.
I understand...thanks for being helpful and explaining....
What I mean by straight is this...
On the mac factory trailer the bunks are flat with 3 points of contact to the trailer...they are made of pressure treated 2x6 they are facing straight up, and have a slight bend in the middle...I realize the boat is not "Flat" I can re-create that "bend" with the bunks flat on the new trailer by adjusting the front supports up...
because my bunks are mounted on the old roller platforms my question is should I have them lay flat, or let the boat "settle" in the "V and make the adjustments then? Right now the bunks will form a "V" cradle...I can adjust the front and rear up and down to create the "bend" that I need....but I wonder if the boards are somewhat "sideways" will it be better, or harder to create that "cup shape" I'll need.....
I have seen both styles of trailer in powerboats...both flat bunks, V bunks, and also bunks that swivel side to side some...
Thanks
