The MacX in early stage came with a fixed spreader, there have been mods on this board to change to a swing arm spreader attachment.
I would look at this if the PO made the change and how he did it. Spreaders on mast is a weak point and any changes could weaken the stress point.
When sailing heeling over to windward, did you notice slack of stays at leeward side?
If rigging is tensioned proper even a strong acidential jibb would not cause a break at the spreaders.
Something here just doesn't add up and wonder why?
kevinnem wrote:I had 2 things I that popped in to my head.
1) I find it odd that the mast breaks at the top - is this typical??? the sail area is triangular - and gets smaller at top - and as such the forces should get small at the top as well.
2) is it possible that the speaders themselfs "pinched" the mast, deforming it and causeing a weak spot?
is there a torque/moment situation that caused this maybe?
Out of curiosity , when it broke did it break "left/right" or "fore/aft"?
Kev.
