Thanks for the well thought out comments. All are right on the money, as usual.
You're correct in that this won't make sailing less work, but it will make it simpler. I do intend to get rid of the headsail--the boat would be way over-sheeted running a jib as well as these wings. By simpler, I mean that while you have to expend more effort, you can sail well with far less skill.Ixneigh wrote:Well I'm not convinced that the two wing sail rig will simplify sailing unless it the jib you just are determined to get rid of. Raising and lowering each wing on a new tack would put me off the idea straight away. I'm lazy and only want new ideas if they are going to be easier. I love to think about new ideas and am all for hard experimentation, but some points occurs to me when advanced for use on a full size Mac.
This a frame, and I have posted about it before, will be more effort to put up and down and stow for transport then the stock rig. The wing sails x2 will also be more effort to stow and cover. And heavier then a few bagged sails.
This is because there's a single, simple maneuver for sailing: Hoist the correct wing for the tack, loose it's mainsheet completely until the wind rotates it to the 0 degree angle-of-attack, and pull back the wing 10 to 20%. That's it--now you've got as much lift as you can possibly get on that tack. So the skill and technique of sailing is dramatically simplified, but the physical effort of sailing is increased: No doubt hoisting these wings is a lot more effort than tacking.
I'm actually worried quite a bit about the time it will take to tack causing loss of momentum, but that's something that will be ironed out when I'm actually sailing this rig. It may well be best to raise the opposite wing loosed before turning, and dropping the former wing after the new wing is set. Although that's not going to work at all in the new configuration I'll talk about next.
Another major factor for this rig is that the trivial sailing skill translates to ease-of-automation: With capstans on the halyards and downhaul lines, a wind instrument, and power winches on the mainsheets with a tensiometer, a very simple piece of software can run this boat. Vic's autopilot for example would provide a platform that with a similar amount of effort as he's expended could control the trim of these sails and turn a boat into an automated ocean-going drone. Solar panels or a regen electric motor/prop can provide more than enough power to operate these sorts of controls indefinitely at sea, so it would be conceivable that a drone built this way could do a circumnavigation on its own.
So for ease of sailing it doesn't get any simpler than selecting a point on a chartplotter and kicking back in the cockpit while the boat sails itself
You're correct that this would be a much simpler proposition on either a catamaran (where it's ideal) or a full-keel monohull. But I like Macs, and I've figured out a way to mitigate the weight aloft problem very simply:Ixneigh wrote:The extra 40 pounds aloft is a big big deal. The M is already too tender. Weighted dagger is more effort and probe to breaking unless a whole new and expensive one is built.
First, there are two centers of effort on a boat: The fore/aft CE we're all familiar with, and the port/starboard CE we never worry about because our mast is centered. When you fly a large drifter or spinnaker, the dramatic healing you see is caused by the fact that the P/S CE of those sails is off-board the boat to leeward, contributing quite a bit to heel. Reference any of Highlander's photos for an example of this
It's a problem I'm very worried about for this rig, because the P/S CE is well to leeward to begin with, and only gets worse as the boat heels. Furthermore, the aloft weight of the wing is off balance and will contribute to heel as soon as heeling begins. It's not a good proposition.
The solution is to swap the wings. While it's easier to conceive of the rig with the starboard wing on the starboard side, all of the above problems are mitigated by switching the position of the wings. Now the aloft wing is on the windward side, the P/S CE is to windward countering heel and moving to the boat center as the boat heels, which is ideal, the mainsheet rigging is simplified and easily made to be on-deck rather than overboard, and the aloft weight contributes to stability until the boat is heeled beyond 60 degrees, at which point it begins to contribute to heel. This is far better proposition for stability in all cases. It does require that the chord of the wing can only be 130% of the beam of the boat however, but the wings I'm specifying meet that already.
The issues with this are as follows:
1) The wings sweep across the deck rather than overboard. On a beam reach, the wing will almost completely block fore/aft topside movement. On a Mac, this means going fore/aft through the cabin. I don't see this as a huge deal, as at all other points, the deck is open and available.
2) Wing-on-Wing performance is destroyed. I may find some combination that will move the boat, but the wings face the wrong way for ideal drag WoW. This means flying a spinnaker for downwind performance. Not ideal, but not any less ideal than a standard Bermudan rig. I'm pretty committed to avoiding a headsail because I don't want to lose full automation capability.
3) The aloft crossbar now has to have spreaders to keep the fore and aft stays out of the way of the wings. That's more aloft weight and complication, and not a trivial engineering problem.
4) The chord (width) of the wings is limited to 130% of the beam of the boat. They happen to be just about that anyway, but it becomes a hard limit because the trailing edge has to sweep inside the beam. It also means that the masts have to be vertical and not canted inward in an A frame configuration. Vertical simplifies the construction of the frame pretty considerably.
I'm going to test both configurations to see which works better in the real world.
These wings can be simpler to produce than a standard sail because their is support every 18", so they don't have to be cut to deal with a lot of unusual force loading. They also won't ever blow out in any meaningful sense, and even if they do stretch a little, it won't matter much. I really don't see them being particularly more expensive than a mainsail of equivalent power, but this is something that only mass production and time will tell. In any case, they won't be twice the price and they should last more than twice as long.Ixneigh wrote:In perfect sailing conditions, the wings may well be faster. Of course, the concept is sound. But it's real world sailing I'm worried about. Three month trips where the boat actually has to sail somewhere because gas is 6 buck a gallon when you can find clean gas. This puts a lot of wear on the sails. Even a production version will run thousands if built light, yet strong enought to stand up. Plus the regular Mac sails are cheap to replace if you mess one up by accident.
A good point, and another argument for keeping a spinnaker for downwind running. An alternative is to use two mainsheets, one on the trailing edge and one on the leading edge, that will keep the wing from moving at all once it's cleated off. But that complicates the sailing of it. A third option will be to bring both wings back to 180 degrees and tie their trailing edges together for downwind running. This will create a V pointing at the wind which should create a lot of drag (which is what you want when running), and with them tied together it would be impossible for them to gybe when running. Whether this will work or not is a matter of experimentation.Ixneigh wrote:Sailing down wind as I visualize the rigging and a frame will increase chances of damaging the wing if accidentally jibed. Uncontrolled jibes do happen dispite our best intentions (what me!?)
In all cases, running is somewhat problematic with this rig and is going to require a lot more thought to solve.
Sound ability to reduce sail area is a necessity, I fully agree. But these wings can be made to do very well at it. Technically these wings can be reefed at each rib, by having a reef line going up through the wing and stopper knotted on the rib in question. This will reduce the wing square footage to match any wind conditions. In practice, I think I'm only going to build in two "reef points" at 25% and 50%. It might make sense to add a 70% reef, but I don't see those winds where I live.Ixneigh wrote:It may make dealing with small squalls easier by just feathering the sail, but the improbability of a effecting a sound, workable reduction in sail is a bad trade off. ESP on a tippy boat. I've slogged across miles of shoals with a double reef and a storm jib, going slow, but feeling in perfect control and in fair comfort. I did not have to pay much attention the the sails.
This mast assembly will have more drag in prototype. In production, we'd use symmetrical foils for the crossbars. There's very little that can be done about the masts themselves unfortunately, because the down wing needs to be stowed aft, and that dictates that the mast point forward which would not be ideal at most points of sail. The added drag of the mast frame should be more than countered by the increased efficiency of the rig overall, so my hope is that this is a minor problem.Ixneigh wrote:Windage aloft and wind drag under power. The stock mast offers little windage if centered. Will the a frame "double" it since there are two upright members now? Will the reduction in height equal things?
Yep, it is more complication. The stowage is going to be fore/aft and dropped to the deck so they'll be along the lifelines rather than over the deck. In my current conception, they'd never be removed, just covered in that place. The masts would have a "knee" joint above the "sail pack" on the masts that would allow the masts to be dropped forward over the bow once the sails are in place and bagged. It would not protrude forward of the trailer hitch in my current conception. That joint is complicated (it also has to rotate) and will not be in the prototype. No point in getting complicated until I know it works well enough to bother with.Ixneigh wrote:Deck clutter. The two wings will take up space somewhere while the boat is at anchor.
In fact, without the central mast, the deck will be far more usable in port and open cockpit designs become trivial and spacious. Furthermore, an open cabin becomes a possibility without a deck-stepped mast. I actually think it will be preferable for deck space. You will have to bag two sails, but we pretty much do that already.
My personal laziness is driving the selection of an existing sailing dinghy. I don't want to rig a rudder or a daggerboard or any of that. I frankly have more money than time because I've got the equivalent of two jobs going on with a mature business I run and a new business I'm setting up. If these experiments go well, it could potentially turn into a 3rd business to run (especially if I want a business whose purpose is to turn a lot of money into a little moneyIxneigh wrote:I will be interested to see the results of the sailing dingy experiment. My opinion (I have one of course;) ) Is save the three grand unless you are wanting THAT small boat. Barrow or buy a round bottom dinghy 2hand. The walker bay no more resembles the powersailor hull the 1/2 dozen others I have owned. It's the before and after data that would be most important. Speed pointing heeling ect.
My 2 cents
Ix
Anyway, thanks again for the excellent critique. It's this kind of discussion that really forces me to think this stuff through, and every concept formalized before building makes this better, faster, stronger, and cheaper.
Matt
