Frank C wrote:wonder if just a small quantity of dry ice would permit stratification - cold at top, down to frozen at bottom?
If you want stratification, I'd think you'd have to pull everything out to put the dry ice on the bottom. I would expect with ice on top, as recommended, convection occurs with cold falling in the center of the cooler, and with the warming occuring on the cooler sides, it rises there.
Frank C wrote:* Is dry ice available in one-inch thick sheets?
I'm sure it is from some sources, but you may pay more for it that way.
Frank C wrote:* If a dozen sheets were kept in a separate small cooler, would they keep longer?
I would expect so... and as they were used the sublimation rate would increase.
Frank C wrote:* Could they be moved one each day to a working cooler, to keep it a little less cold than frozen?
I would think anything near the dry ice would be frozen at or near -100F. As the quantity of dry ice varied from a fresh piece in until time to replace, there may be some contents in the cooler thawing and refreezing, depending upon what point that occurs for that item.
Frank C wrote:* How costly is dry ice?
I have no idea, but like most things, it probably varies with location.
The best use I can see for dry ice is to have a cooler for refrigerated stuff, kept cold as long as possible by water ice and as many frozen contents as possible, and an auxiliary cooler with spare ice extended by dry ice. The spare ice would be transfered as the contents and ice in the refrigerated cooler are consumed.
Frozen contents really help the refrigerated cooler stay cold longer. For example, with our Ice Cube cooler, using as many frozen water bottles as possible, with as much ice packed around them as possible, and the remaining space filled with refrigerated water, would be about as optimal a situation as I could imagine. No dry ice involved.
Moe
