Quick heron H-412_D Windlass
Well this will be another of my spring mods , got this for a song , a display model on clearance , they even through in the relay contactor & dash swicth & it came with a manual handle, chain gipsy is power up-down & free fall the capstan pulley can be opperated seperately or with gypsy , power is either from dash mounted switch or built in switches under top cover
http://i844.photobucket.com/albums/ab1/ ... 5455d3.jpg
http://i844.photobucket.com/albums/ab1/ ... 6f04bf.jpg
http://i844.photobucket.com/albums/ab1/ ... f3c08c.jpg
trdprotruck
Re: Quick heron H-412_D Windlass
Post by trdprotruck »
Nice Score! Keep us up to date with this mod.
-Randy
Crikey
Post by Crikey »
Gonna mount that on your chain locker cover? :|
R.
Crikey wrote:Gonna mount that on your chain locker cover? :|
R.
Ross
Yer killing me here :D :D :D :D , Yes technically I am it will be mounted on a hinged brkt above the anchor locker lid so that will give it even more drop zone for anchor rode :wink: , the front hinge mount will be attached to my anchor retainer brkt which is already attached to the deck bow & hull with triple reinforcement = :idea: , the rear cross T- section of the brkt will be attached too reinforced brkt's coming from the already mounted rear bowsprit hull mounting brkt's this will be installed under the anchor locker lid , but above the anchor locker well inside it :idea: & already reinforced points @ the bowsprit aft mounting hull brkts will support this rear mounting brkt , . this set-up will let me unlock hinged windlass/capstan lift anchor hatch lid open , relock windlass in down poss. with just one 1/2" X 5" locking pin drop / retrieve anchor rode no need to be cutting anchor locker lid into two sections already drew up plans & modified them three times already :) trying to make it cosmetically pleasing to the eye & the boats isometrics has to look like it belongs their :arrow: :idea:
Crikey
Post by Crikey »
Nicely thought out John. You obviously haven't been caught with your Kilt down, with this one! :o
Keep those pictures flowin...
Do you have SS tube bending capabilities at your employ? I've got another mod you might be interested in.
R.
u12fly
Post by u12fly »
This one is on my bucket list for next winters project.... So keep up the good work I have things to learn 8)
Chris.
u12fly wrote:This one is on my bucket list for next winters project.... So keep up the good work I have things to learn 8)
Chris.
Hi Chris
This is gonna be a pita of a mod , only good thing for me is all the access points have been already installed so once my design is done & I have it made the mounting brkt's & have it ready to install the rest will be easy as all the re-inforced mounting brkts r already in place inside the deck & hull from when the 4ft bowsprit was installed , only the anchor locker T-section brkt mounting hrdw from Hull to Anchor locker will have to be measured & made once all the floation is removed again for access to measure & install I have already installed extra wiring in that area 4yrs ago for future mods so I will likely complete the installation of these to the top deck area for these mods so as I do not need to go back in there again for a while, re-installing the floation is like a jig-saw puzlle :? :D :D
Of coarse this is a two person installation :( so thats another problem when u live alone :|
Once she is installed then theirs the wiring & battery issue
PS waiting on the battery I want to go on sale :wink:
well here's a mock-up mounting brkt I'm designing the top plate hinge will be cut in half two make two 1-1/4" wide hinges & mounted on the top plate & the base hinge will go in between them this will be mounted onto my already re-inforced anchor base holding brkt shown here it is about 9" high off the deck this will be reduced 4 or 5" this will allow for an 11-12" rode drop into the anchor locker
http://i844.photobucket.com/albums/ab1/ ... b42895.jpg
http://i844.photobucket.com/albums/ab1/ ... 609c41.jpg
http://i844.photobucket.com/albums/ab1/ ... 812c1d.jpg
u12fly
Post by u12fly »
ahhh, progress! I love it when a plan comes together! 8)
seahouse
Post by seahouse »
Nice project John-
Where did you unearth the aluminum extrusions? Inquiring minds want to know.
-B. :wink:
Crikey
Post by Crikey »
Fall off the back of a truck? :o
seahouse wrote:Nice project John-
-B. :wink:
I take it u r talking about the Alum commercial door hinges for transport trl's !
Crikey wrote:Fall off the back of a truck? :o
this did for this price LOL they had two of them I ph them on the Mon to get all the info , called them back on the Tues for more info only one left so Wed morn I went striaght down their & grabb the second one :D :D :D :D , got a reversing relay & dash mount switch thrown in with it also :wink: :P
QUICK HERON WINDLASS
Windlass clearance....Display model, no box, no manual, some marks.
Windlass and manual handle. GYPSY AND DRUM MODEL. Has up down switches mounted on windlass.
400watt $399.00
click on windlass in the center heading just below the store pic
http://www.hollandmarine.com/
Crikey
Post by Crikey »
Nice .... waiting. :)
