The construction method we're using looks to work perfectly fine, so we will stick with it for the full scale prototype. We're making the ribs out of 12mm marine plywood and stapling 4 oz. dacron sailcloth to them. When tensioned, the assembly takes on a perfect wing shape as I'd hoped. We're finishing the top and bottom of the wing by stapling the overlapping sailcloth to the top rib and then bolting another rib to that above it, which will clamp the sailcloth between the two ribs and give it a finished look.
Wingsail under construction by mastreb, on Flickr
We do have to tension both the leading and trailing edges in order to keep them in perfect shape. The leading edge is easy, but the trailing edge I have to do some thinking about because it's so thin.
The mast and rigging is also working great. We're using 1.5" aluminum pipe made for speedrail, and using their fittings as the masthead and mast foot.
The wing goes up and down better than I'd hoped:
http://www.flickr.com/photos/68241682@N ... hotostream
It's considerably easier to raise and lower than a typical mainsail. We had thought we would need to use UHMW bearings but simply having slightly oversized holes for the mast in the ribs work great. The dacron does have to be "crunched down" a bit by hand when lowered to the bottom, but that's okay.
So far, everything is working great so it's full speed ahead.
