Rudder rope?
Rudder rope?
I want to replace the rudder ropes (rudders two btw) on my :macx: before launching it. Looks like 1/4" or 3/8"? How long should a :macx: rudder rope be? :?
SeaGriff
Re: Rudder rope?
Post by SeaGriff »
Use 3/8 bungee cord, 12ft for each rudder. It works much
better than rope.
Re: Rudder rope?
Link? There are many qualities of bungee cord. 8)
SeaGriff wrote:Use 3/8 bungee cord, 12ft for each rudder. It works much
better than rope.
MAC-A-TAC
Re: Rudder rope?
Post by MAC-A-TAC »
I replaced the rudder lines on my M, but I don't remember the length. You could tape a smaller diameter line to the existing rudder line and pull out the old line and measure it, then the thin line could be used to pull new line through the rudder hole.
Good luck.
God > Family > Country
Mac Out.
SeaGriff
Re: Rudder rope?
Post by SeaGriff »
I just picked up 3/8 bungee cord from my local Ag supply. They sell it
for secureing tarps. Works good I don't have a Link for it.
canmac27
Re: Rudder rope?
Post by canmac27 »
Why is bungee chord a better option than rope for the rudders?
Thx
Ormonddude
Re: Rudder rope?
Post by Ormonddude »
canmac27 wrote:Why is bungee chord a better option than rope for the rudders?
Thx
Lets the rudder kick up if you hit ground the rudder will be held to the tension of the bungee hopefully saving your rudder.
Re: Rudder rope?
That's an interesting idea. Mine has two separate lines to each rudder, and I certainly could use a bungee for the hold-down line, maybe with a loop at the right length to tension the bungee to hold the rudder down and a stopper knot for when it's released.
Or spliced (some how) end to end with the 'raise' line, so it's just one loop. I don't know how I'd splice bungee to braid, though. :?
capncarp
Re: Rudder rope?
Post by capncarp »
I like the idea. But, how far does it stretch when you pull up a water filled rudder? Depending on how tight you have the rudders shimmed, they can get pretty heavy. I assume you just route it the same as Mac sets it up using stopper knots at the rudders. Any pic's?
capncarp
99 :macx:
raycarlson
Re: Rudder rope?
Post by raycarlson »
search on rudder kick-up mod. we've been doing this one for years.you only use bungee on the pull down=hold down side, the lift up rope stays normal.
reastmure
Re: Rudder rope?
Post by reastmure »
raycarlson wrote:search on rudder kick-up mod. we've been doing this one for years.you only use bungee on the pull down=hold down side, the lift up rope stays normal.
I did a search on rudder kick-up mod but no results came up either in the mod section or forum??
csm
Re: Rudder rope?
Post by csm »
West Marinw asmteel or equal dynaneen rope for both center board and rudders. Snap lock cleats for the rudders are great; they POP when rudder hits ground, releasing/saving the rudder and giving an audible shallow water alert.
Re: Rudder rope?
Cool = just ordered Amsteel in 1/4" black. 8)
Length is 10-12 feet btw.
csm wrote:West Marinw asmteel or equal dynaneen rope for both center board and rudders. Snap lock cleats for the rudders are great; they POP when rudder hits ground, releasing/saving the rudder and giving an audible shallow water alert.
acmaui
Re: Rudder rope?
Post by acmaui »
I used 5/16" and added a pair of blocks to make it a lot easier to raise them.
