Galley Top, Is this a mistake?
Re: Galley Top, Is this a mistake?
I recommend against using a laminate bevel-edge router bit around the outer edge of the piece, and instead I suggest a vertical cut, as I noted in my first posting. The reason is that if you bevel it around the outer edge, that rounded edge, combined with the slightly outward bevel of the inset fiberglass galley top will leave you with a 'trough' around the rim of the laminate and it will henceforth catch crumbs and dirt and be difficult to clean. By using a vertical cut, as I did, and making a very accurate template, you will make the laminate virtually flush against the edges of the galley and hence make it much easier to clean.
I do recommend, as I noted in my original response, that you use a laminate bevel-edge router bit around the opening for the sink so that you reduce the chances of any chipping of that opening and also provide a smooth transition to the sink itself.
seahouse
Post by seahouse »
You can buy saw blades....
... with the teeth reversed to cut from the top side.
Yup - in a jiffy it's an easy matter (it takes seconds to do) to make your own reverse blade from a standard blade using a bench grinder by grinding the teeth at what would normally be the point of the bit. Just as you would (or, at least I do) for a normal blade if it had broken off at the tang. Some tang shapes are easier than others to replicate, and some blade holders are more tolerant than others to size variations.
Since you're now cutting from the top; if cutting more scratch-prone materials (Formica is pretty forgiving in this regard, but even it can be scuffed by its own chips caught between the vibrating sabre saw base and the material) you can apply tape to the base (shoe) of the sabre saw as a cushion. I like electrical tape for this, but whatever's available will do the trick.
Which is why I just cut from the back. You don't need to apply tape, worry about the surface or buy (or make) reverse saw blades. Just flip over your template and off you go!
Sumner
Post by Sumner »
kmclemore wrote:....Which is why I just cut from the back. You don't need to apply tape, worry about the surface or buy (or make) reverse saw blades. Just flip over your template and off you go!
There primary purpose is cutting out sink openings in countertops where you can't cut from the back side but I've also cut a counter tops out at ...
...an angle from the top like above in our kitchen where one end is cut at an angle. Since they cut so nice I'll also cut other pieces from the top (not Formica) as it is quicker to layout and cut but both methods have their good and bad points :) ,
Sum
Our MacGregor 26-S
Our Endeavour 37
Mac-Venture Links
Oh, wow. Sorry Kevin. My short-term memory is bad and getting worse. :( I remember reading that now.
Wait - what are we talking about again? :?
tkanzler wrote:Oh, wow. Sorry Kevin. My short-term memory is bad and getting worse. :( I remember reading that now.
At least you didn't say bad and getting badder :D
Erik Hardtle
Post by Erik Hardtle »
Suggestion... Start with cardboard and contact paper....
Then do the real thing...
Im not even getting paid to roof this house, but the owner is hot and makes my meals and provides other benefits too...so whose the fool now??
:wink: :wink: :wink: :wink:
Catigale wrote:Im not even getting paid to roof this house, but the owner is hot and makes my meals and provides other benefits too...so whose the fool now??
Did you meant to post this to this thread??!? :?:
How did this end up over here? Even the mods on this forum are getting banned.... :D
I'll clean this up today
I thought I was missing something. I guess I am, but it's interesting nonetheless. :D
Divecoz
Post by Divecoz »
My older brother sent me some short videos of, his son-in-law The ER DR. on St Croix and his best friend a PhD in Chemical Engineering as they tried to help him repair the roof on the Dr's house on St Crioix ..Then as they tried to Repair some soffit and fascia and hahahaha a very poor attempt at driving a ground rod... I can only hope you are doing better than those 2 guys.. :o :D :o :D
