What is an open eye clip?
Google found this
[/quote]
Yup!
That is a DOUBLE, and it's exactly what I use to hold the furler to the forward mast raising line when stepping the mast - works great. Both ends are OPEN eyes so with enough weight you could easily bend the eye open. I'm thinking only 600 to 800 pounds would do it or
two people. (Not suitable for climbing mountains!)
THANK YOU FOR THAT POST! It explains EVERYTHING! Saw the picture of the mast "pinned" I notice he flattened the mast plate to do it - I might consider doing that because I have no vang - I need to think about it.
Those are really big and expensive and have only one eye, but it's good to know there is a single eye that can take some weight. I need doubles, but those sure look nice too.
Yeah, 100 pounds is considered dangerous in my book - that is weak enough to let a boom take out a crew member when it lets go, and 200 pounds is not even enough to support my own weight - that's why I thought "coat hangar" when I saw it cuz I visioned myself trying to hang from it.
In fact, some carabiners have pretty high load ratings, though I'm not a big fan of carabiners for things like topping lifts and such. I like 'em for fenders and other 'utility' type applications.
I like those too, but Carabiners are not open eye really because they reconnect with themselves when they close and that is why they are okay for mountain climbers. Anything that is not "open" is usually pretty strong. I have considered those, but for some reason i have also not been a big fan of carabiners (wonder why?)
Just trying to make the point that if it's load rated, and that rating is adequate for the intended load (and overload), then the actual style shouldn't be a concern. The style should, IMO at least, be whatever is best for how you use it.
Got it - I will remember that. The way I use those is to clip one thing on one end and then clip the other end to something else - so I usually need a DOUBLE OPEN EYE. I still have not really found one stronger than 300 pounds that is not heavier than the boat. I carry them around in my pocket sometimes instead of Velcro. I am assuming you guys are all using the "Pelican Hook" style to connect the mainsheet block to the boom bale?
