Had a couple mishaps getting her in the marina...wind was blowing pretty well, and I accidentally left the swim ladder down. Getting the boat off the trailer and halfway to the slip I managed to break the steering that was just replaced (helm unit...this time, I pushed the steering sheath out of the helm unit, which I was able to fix with the help of another 26X owner who happened to be in the same marina, go the steering back working...gotta remember to keep that darned swim ladder up! Chris, if you happen to be on this forum, thanks for the help!), and hooked a boat ramp overhang with one of the shroud lines which broke one of the spreaders off (which was already bent and slated for replacement...I've actually got the replacement spreader cut and drilled, and waiting on the boat...just didn't have time to replace it yet).
Anyway, lady friend and I did manage to get out and enjoy the Intracoastal waterway and Carolina Beach Inlet between CB and Masonboro Island (motoring since the spreader is broken at the moment). Was really pleased with the new Suzuki DF50 that I've had installed on it...quiet, smooth, starts first spin, doesn't seem to use much gas, etc.
On to the question...we beached the boat twice, bow first, and both times the wind blew the stern around so the boat was beached sideways. The second time both the wind and some big waves were pushing the boat into the shore. That's good if you want to stay there, not so good when you're trying to leave.
So, what's a good way to do this better? Big, heavy anchor off the stern? Some stern anchor poles (like I've heard fisherman use in shallow water)? I've seen someone mention using a large pump to quickly drain the ballast tank to get un-beached. I think this would be much easier if I just keep the stern from blowing around sideways. What's the best way to do that?
