Thanks
Brian
That seems wrong. You would be boarding and the seat gets in the way. Yea, I would install yours on the port side for easier boarding.BNG wrote:The seat swings to the starboard side and the current OEM ladder is on the same side.
Not right! I got my 26m direct from Laura. ladder is inclusive. I guess it is becouse of CE what we need in Europe, also bilge pump an stern rails came with it.RussMT wrote: BTW, the Macgregor factory never installed ladders. Any ladder you have installed came from a dealer or PO.
In my opinion, for safety sake, these boats should all have some kind of boarding ladder.
BNG wrote:I'm installing a transom ladder from BWY on 26x and not sure if just screws will be enough to hold the mounts securely. Will it hold 230lbs Should I bolt thru?? I also was thinking about installing on the port side because of the swing on seat for ease of entry and exit. Has anyone been there and done that.![]()
Thanks
Brian
Dimitri-2000X-Tampa wrote:I just switched my boarding ladder backing from small washers to large washers and then sealed with 5200. Solid as a rock now. I would never consider screwing something like this in, should always be thru-bolted. I guess my ladder (port side) was probably also installed by the factory, but with small washers which I have now replaced. I've pretty well got my kids trained to put the ladder up now when we are backed into a beach some place. Because if the tide goes out and the ladder is down, can put too much stress on it. I wouldn't want the boat sitting on that ladder.
Its a good idea for safety too, but I think as long as the engine is down, I can climb up that too.
BNG wrote:That's a good point DaveB. I didn't consider the ballast handle being in the way if I moved it to the other side. I can see everyone tripping over that. I wouldnt mind keeping the ladder I have but it's one step too short.
Good practice, Bill!Bill at BOATS 4 SAIL wrote:The transom ladder on the Macs was a MacGregor factory option. I always had them installed on the hundreds of Macs I sold because I considered it a safety feature.
