etec input needed
seahouse
Re: etec input needed
Post by seahouse »
Bravo about the engine!
Some outboards spew water out with the exhaust stream, which is split from the through-hub exhaust, to indicate a functioning water pump. The E-tec is one, and I think it's right below the hose attachment point.
With any outboard you want to shut down immediately if water does not spew out somewhere shortly after startup. Part of the startup procedure with just about any boat, no matter the engine, diesel, gas etc. is to check for "spew".
:wink:
bahama bound
Post by bahama bound »
seahouse wrote:Bravo about the engine!
:wink:
I kinda assumed that with the foot in the water the flow reversed and the pee hole is the same hole that the hose screws on to ? Its amazing how different this motor is than a conventional 2 stroke .
dreamer
Post by dreamer »
I have a 2008 etec 60 and it's been great. The pee hole is the same one that you can screw a garden hose to reverse flush. By your description it sees as if the rubber hose that attaches to the hole inside the cowling may have come off, I think it's held on with a zip tie and if you flush with a garden house and turn up the water too strong it could loosen this hose. Open the cowling and check that this hose is attached to the inside of the pee hole.
bahama bound
dreamer wrote:I have a 2008 etec 60 and it's been great. The pee hole is the same one that you can screw a garden hose to reverse flush. By your description it sees as if the rubber hose that attaches to the hole inside the cowling may have come off, I think it's held on with a zip tie and if you flush with a garden house and turn up the water too strong it could loosen this hose. Open the cowling and check that this hose is attached to the inside of the pee hole.
I suspected something like that thanks ! I will pull it off and check ....do you know if your etec uses transom wedges ?
seahouse
Post by seahouse »
dreamer and I both have M's. I don't have transom wedges on mine, but an X, such as you have, might be different.
The factory does not put wedges on ETEC-60s on Mac 26Ms.
vkmaynard
Post by vkmaynard »
We were testing on Bill P M with the Etec 90 last weekend.
Ran really great and not loud. Vibration no problem, smoother than the newer Suzuki 90 at 3000-3800 RPM. Maybe a little more exhaust smell at low speeds than the Suzuki (could be old gas).
You should hang the motor and try it. If you don't like it, the next motor will use the same bolt holes with little effort.
The small cowling size is a BIG plus.
Victor
If you don't want it in the end, I'll buy it when I'm down that way this summer. 8) :D
My :macx: could really use a few more ponies than my BF50 can deliver. :cry:
Beene & I Installed wedges on both our :macm:
bahama bound
Highlander wrote:Beene & I Installed wedges on both our :macm:
I hate to sound stupid but if a motor has tilt and trim and trims the full range up and down what are the wedges for .I know someone posted they got a little performance with the wedges ?
fouz
Post by fouz »
I'll buy it if you don't want it :)
wbpenney
Location: Cary, NC - 'Boom Boom ll' 08 26M 90HP E-TEC http://boomboom2.blogspot.com/
Post by wbpenney »
I added wedges to my M, and it allows me to push the bow down( or the stern up) more. This lets me to see over the bow while seated, and actually gain a few miles per hour.
bahama bound
wbpenney wrote:I added wedges to my M, and it allows me to push the bow down( or the stern up) more. This lets me to see over the bow while seated, and actually gain a few miles per hour.
O.k now I get it ! Are the wedges reversed to get bow down ?
Gazmn
Post by Gazmn »
Yes. the thick, fat side is put through the topbolt on both sides; Slim side through the bottom bolts. To Answer old question, you should get at least 18kts - if not more - be careful.
Re: props try: 14x11 big ear pontoon prop. or a 13 3/4 x 11 or 13pitch. Use the prop that gives you full RPMs of 5500, regularly loaded.
Seapup
Post by Seapup »
The wedges are not too necessary on an X, supposedly do a more for an M. You can keep the boat nosed down to avoid plow mode a bit longer, but normally at speed I adjust the extra angle out immediately and go a little past neutral. I have an adjustable jack plate doing the same thing as wedges, you can set it straight or 6 deg wedge angle. The one I have can be used as a 2.5 or 5" setback and it spreads the load across the back of the transom. If you are going to remount the motor and add outside plates and wedges an adjustable plate may be worth a look. Gazmn has a 10" on his etec 90.
Saw this chart today checking out the etec pontoon models. Its part of an evinrude ad... but here is their numbers for a 23' 2300lb pontoon with an etec 90.
