That's a great idea. They are there for safety only and don't need to be torqued down or anything. Much better than a bolt. I may steal this idea.bnix00 wrote: For trailering I ditched the bolts and replaced them with SS Clevis pins with hitch pin clips- no tools needed. I have also launched with the pins still in. Luckily it was nice weather and warm chesapeake water for my swim
I was lucky the dock was low and my son could get a wrench on the thing. I normally don't tighten them beyond a half turn once the nylon catches. Still too hard to turn by hand underwater.
The next logical progression of this thread is how do you hold rudders DOWN while underway. I've seen many use break away cleats to solve the problem. What I found works well is simply pulling the "down" line through the cleat and then wrapping around with the tail to create resistance. The wrap will allow tension to hold the rudder down. If the rudder hits something, it will pull through the tension of the wrap over it and lift up. Simple.
