Battery ventilation on 26x
tp56ihs
Post by tp56ihs »
Just wondering about battery ventilation. My 1996 26x has 2 batteries under the seat aft of the sink. If I charge these lead acid deep cycle batteries in the boat there will be some hydrogen gas generated. Do you think that the cabin ventilation is good enough :) or should I somehow vent :? or move batteries :( ?
Re: Battery ventilation on 26x
Unless you've somehow hermetically sealed the access ports to the bilge, I doubt you'll have a problem. Hydrogen gas is very light and will escape quite easily using the first crack it finds.... similarly, it will also escape your cabin through the hatch. I've never heard of a battery explosion on a Mac. That being said, the usual precautions should be observed when charging - disconnect the charger from the mains BEFORE you disconnect it from the battery to avoid sparks (right near the source of the hydrogen gas).
That space is open at both ends (under the galley and into the stern 'bilge'), allowing for a lot of diffusion and dispersion. Those spaces are far from air tight. I don't worry about it, but you could always add a louvered vent to the cabin in the vertical surface that makes the front of the seat pedestal, if you want more air flow through that area.
Hydrogen won't build up in a Mac. It's very aggressive about moving up and actually only collects in sealed dome-like areas. There's nothing like that on a Mac that's rightside up. No need to worry about battery ventilation on these boats.
Chinook
Post by Chinook »
One thing you might want to pay attention to involves the installation of electronic components. It's sometimes tempting to install small things inside the battery box. When I was installing controllers for my 2 solar panels, I noticed that the instructions advised against installing them too close to the batteries. I'm not sure, but I suspect the manufacturer felt there was possible hazard spark. I installed mine on the outside face of the battery box, in the aft berth airspace.
seahouse
Post by seahouse »
Under some situations batteries (mostly flooded lead-acid, but others do at times as well) emit toxic acid vapours, or it can splash when being checked, handled or filled. Pull a cap off a discharged battery being heavily charged and hold a flashlight up to the electrolyte if you want to see a visual demonstration of the vapours being generated.
Also witness the corrosion that happens at the terminals - it's mostly from the close proximity to the acid fumes and vapour coming from the battery. I would not want any sensitive electronics, or anything sensitive to corrosion anywhere near that environment, particularly in a confined area. Newer flooded lead-acid batteries have a porous recombinant matrix inside the caps that helps this but does not eliminate it. The matrix also somewhat "explosion-proofs" (like a flame arrestor) the battery itself from flammable gasses (from an ignition source outside the battery case) as well. It's one reason to not remove the caps from a battery when recharging it, like they did in the old days before the caps were made this way.
-Brian. :wink:
Well I installed a bilge blower for various reasons & purposes of ventilation
http://i844.photobucket.com/albums/ab1/ ... 010053.jpg
I have two of these adjustable vents one in the head the other in the V Berth
http://i844.photobucket.com/albums/ab1/ ... 0009-1.jpg
http://i844.photobucket.com/albums/ab1/ ... 010021.jpg
http://i844.photobucket.com/albums/ab1/ ... 010005.jpg
I also installed grill vents in the front of the rear S/B dinette seat & on passage side of the same seat where the ladder is as my battery charger is there & creates a lot of heat in there this also gives lots of ventallation for the batts
tp56ihs
Post by tp56ihs »
Thanks All. Good info I feel better now. Thin I will keep any electronics out of the battery area. :)
bobbob
Post by bobbob »
Would this be a concern with AGM batteries?
seahouse
Post by seahouse »
AGM's vent too, but very rarely, and under unusual circumstances. There is a valve that opens to release gas when it exceeds a certain pressure. Below that (which is normally) and it's a recombinant effect; the gasses get "recycled" back into the chemical process.
