I ordered these LEDs to replace my interior incandescent bulbs on my 09' 26m:
http://www.amazon.com/gp/product/B00EKK ... UTF8&psc=1 (White lights)
http://www.amazon.com/gp/product/B00IJI ... UTF8&psc=1 (Red lights)
Upon trying a single bulb of each type in my lamps, none worked. I had read on here that sometimes the polarity needs to be reversed with the LED bulbs. On my boat's lamps, the tip was positive and the base was negative. I have a main battery, leading to a circuit board, and on this circuit I have a stereo and the 4 interior lamps. So I switched each lamp's wiring attachment clamps from one to the other with the circuit off...after reversing them all, I turned on the circuit, checked to make sure the stereo still worked (unmodified) and then tried a different LED in each lamp...nothing. I then tried the incandescent bulb in each...they all worked. I then took a voltmeter to each lamp to ensure I hadn't made a mistake when I switched polarity (in case they were sequenced)...all of them now had the tip negative and the body positive (opposite original). The stereo never wavered in it's functionality with switches on/off or bulbs in/out.
So I think I have tried every possible electrical configuration and used different bulbs in every case (in case I blew one out) and I've tried all 6 bulbs at the end to detect just a bad bulb...nothing.
The only unknown at this point is that the packaging for the white bulbs says "GRV Ba15s 1156 1141 High...right Cool White Pack of 2 New"...and I don't know what the 'high' and 'right' refer to (car signals?)?
I'm perplexed...and yes...evidently, it does take this Floridian several hours to order and replace a light bulb!!
Please help if you have any thoughts and thank you in advance!
