Motor support bracket for trailering, bodged from 1"X 1/16" aluminum angle, a piece of scrap 1/4" Spaulding fibre (so it won't rust or damage the paint on the motor), a spring (I forget where that came from), and a couple of 1/2" bolts and nuts.
The inward facing bolts are bent so as to be parallel when they enter the bottom holes in the motor mounts. With the motor up, the thing gets sprung open and snapped into the holes in the mounts, then the motor is let down onto it. When the motor is lifted up far enough again, it disengages the bracket which drops down out of the way, so the motor can then be lowered, which I do upon arrival at the storage facility.
For seasonal storage the batteries are out (I have those on a quick-release bracket too, BTW), so the red relief screw must be opened, and the motor is raised or lowered by hand. Its movement is still damped by the hydraulics, so if you just let go it takes a few seconds to drop down completely. This also damps any bouncing when trailering over potholes, which might otherwise allow it to release and drop down unintentionally. (I followed the boat once when someone else was driving the tow vehicle, so I got a chance to see this and other things first-hand). The extra holes were for tie downs for long trips, but I didn't know they would not be necessary at the time I made the bracket.
