Name & Order of Your 3-5 Most Important Mods
- topcat0399
- Sailboat: Venture 2-24
Re: Name & Order of Your 3-5 Most Important Mods
Top 5 important mods hmmm...
1. Anchor Roller
2. Anchor Roller
3. Anchor Roller
4. Anchor Roller
5. Have pretty much modded EVERYTHING else but
none have been as important as the - you guessed it: Anchor Roller.
1. Anchor Roller
2. Anchor Roller
3. Anchor Roller
4. Anchor Roller
- millcity
1. Quality Bluetooth radio and speakers
2. Solar Panel, inverter and LED lights
3. Magna Grill
4. Anchor Roller and anchor
5. Chartplotter
3. Magna Grill
5. Chartplotter
Retcoastie
1. Autopilot (mostly single handed trips)
2. Edgestar 12VDC refrigerator
3. Pressure water system
4. Solar panels
5. Lazyjacks
4. Solar panels
5. Lazyjacks
- Ixneigh
Here's my storage thing. Everything is removable with hardly any screws if I ever sell the boat it's very easy to return the inside to stock.
Ix
topcat0399 wrote:Top 5 important mods hmmm...
1. Anchor Roller
2. Anchor Roller
3. Anchor Roller
4. Anchor Roller
millcity wrote:4. Anchor Roller and anchor
Hmmmm - starting to see a pattern here.cptron wrote:4. Anchor and Anchor Roller
- millcity
I use mine primarily to ram other boats that get in my way.Tomfoolery wrote:topcat0399 wrote:Top 5 important mods hmmm...
1. Anchor Roller
2. Anchor Roller
3. Anchor Roller
4. Anchor Roller
none have been as important as the - you guessed it: Anchor Roller.millcity wrote:4. Anchor Roller and anchorHmmmm - starting to see a pattern here.cptron wrote:4. Anchor and Anchor Roller![]()
- Bobglas
Geesh! I could use a wheel lock! Ixneigh, can you post or e-mail how you did that? Picture?Ixneigh wrote:In order of completion and importance
1 storage units for clothing and sundries. Geesh where do I put everything??
2 helm seat mod. Split the vertical and seat, made seat flat. Geesh this seat is clunky.
3 wheel lock. Geesh I got no one to steer while I put the dang sails up
4 skegs on bottom. Geesh this boats squirrly under power
5 anchor windlass! Geesh pulling up the size anchor you need to park these things is tough
6 custom sunshade.Geesh I'm getting frickin sunburnt
7 companion way slide slide boards. Geesh that big one piece things a pita
8 different nonskid and extra glass on deck. Geesh the thin deck really bugs me
9 extra strong boarding ladder that fits on the corner of the stern. Geesh I needed a way to climb up.
10 different traveler control lines. Geesh I needed to get rid of this clunky end cleats on the track.
And more too.
Ix
Seeing that shiny anchor makes me instantly think of this.
"Hey! You scratched my anchor!"
- dlandersson
[quote="dlandersson"]1. Swim platform
2. Auto pilot
3. Improved shelves
4. 4 bladed prop
2. Auto pilot
3. Improved shelves
4. 4 bladed prop
- Gazmn
Thanks Ix & others for pics & references. It really helps us to copy - I mean conceptualize
- kurz
What is the advantage of a 4 bladet prop? Which motor do you use?dlandersson wrote:dlandersson wrote: 4. 4 bladed prop
- dlandersson
I've got a 98 Merc 50HP. I understand a 4 bladed prop is better for towing tubes, etc. I'm not so worried about getting the last possible .5 knot at WOT.
kurz wrote:What is the advantage of a 4 bladet prop? Which motor do you use?dlandersson wrote:dlandersson wrote: 4. 4 bladed prop
1. BWY engine quick disconnect
2. Magma Grill
3. Bimini
4. Chartplotter
5. Hatch arm to hold it open
Roller head sail
Washdown Pump
12v electric fridge
LED bulbs everywhere
Dodger
Boarding ladder
Pressure water and extra water storage
Solar panel
Dual axle
Galley Mod
Cockpit cushons
New breaker panel
2. Magma Grill
3. Bimini
4. Chartplotter
Roller head sail
Washdown Pump
12v electric fridge
Dodger
Boarding ladder
Solar panel
Dual axle
Galley Mod
Cockpit cushons
New breaker panel
- Berber Boy
- Location: Paynesville, VIC 3880 AUSTRALIA WindSong 2016 26M 75hp Etec
Here are my most important ones:
1: Boomkicker - Better sailshape and dispense with topping lift
2: Mastgate to keep Mainsail lugs inside mast track allows sail to come down & pack tighter
3: Lazyjacks - Quicker downhaul with no mess
4: NMEA network connecting plotter/ engine/fuel flow/ VHF DSC
5: Helmsman swivel chair - More room and adjustable
My boat came with anchor roller and in- cockpit rigging
BB
BB
Yes and Yes, but just out of my top 5.Berber Boy wrote:Here are my most important ones:
BB
