What are these?
Plebian
Re: What are these?
Post by Plebian »
the one on the right in the last pic looks like a boom connection
Don't know what the one on the left is, but the shiny metal part is a fairlead for looping a line around, maybe some sort of bumper holding gizmo.
jkfinity
Sailboat: MacGregor 22
Re: What are these?
Post by jkfinity »
I bought my first used boat couple of years ago (still considered newbie). I wanted to get some extra help identifying the boat, what parts went where. I hired a local sailboat repair expert that does house-calls to drop by my house and do an eval. Well worth the money for 2 hours worth of work from someone who knows what he's doing.
At one point I asked what this bag of leather harnesses was for. I had guessed, since it was a smaller dinghy, that perhaps it was for fastening to a cable and doing performance hiking, leaning over the hull on your toes. He glanced through my gear, rolled his eyes :o :o :? :D and said, "this is all horse tack gear. has nothing to do with your boat at all".
Oh.
Thanks. Here's your money :o
sailboatmike
Re: What are these?
Post by sailboatmike »
That would be a Cunningham hook for hooking mainsail in to keep it down on the boom to control sail shape, used most often when you reef your main to create a new Tack for the main
http://www.spinnaker-sailing.com/lesson ... index.html
Wind Chime
Re: What are these?
Post by Wind Chime »
sailboatmike wrote:That would be a Cunningham hook for hooking mainsail in to keep it down on the boom to control sail shape, used most often when you reef your main to create a new Tack for the main
I suggest: THIS IS A REEF HOOK - It is where you hook the "reef cringle" (of the tack corner) of the mainsail when your are reefing the mainsail.
Mac's did not come from factory with a special cunningham hook on the gooseneck, or a special cunningham cringle in the standard mainsail.
This may stir up a hornets nest of conversation - but ...
- a cunningham is:
a line that goes from the gooseneck area (where this reef hook is situated in the photo) to a special cringle just above the regular tack cringle. The control end of this line can also be led aft for easy operation.
- a cunningham is used to:
pull down on the mainsails lower luff, used together with the main halyard tension to adjust the "draft position" of the sail fore and aft (but does have a small affect on the "draft depth", while the outhaul mostly adjusts "draft depth" but also has an affect on the "draft position" slightly).
* on many boats it's easier to adjust a cunningham "on the fly" than adjusting halyard tension - to change draft postion.
ps;
I have a cunningham line on our Mac from this reef hook to a sail slug cringle - it works ok, but very small amount of gain in sail shape. Mostly for MacTweekers :)
Re: What are these?
Interesting. My X has it - and I always have assumed it's a reef hook. 8)
Wind Chime
Re: What are these?
Yep, I'm pretty sure it's a reef hook (which came standard), not a Cunningham hook.
