I have recently started sailing my 1989 26D, which is my first boat, so I'm learning as I go. It seems to me that my mainsail is too baggy. The sails don't seem to be in a bad shape, previous owner said they were "remanufactured" or "reconditioned" by SailCare, whatever that means. He only knew what first owner told him (he only had it for one season). But compared to a smaller original jib I got with it those sails look relatively new, white, furled genoa has a nice red cover band (is tere a name for it?) and generally look very neat, all sail covers are not faded at all etc. I don't know much about sails but they don't look old or worn to me. But maybe it's baggy because it's old? Boat doesn't have a boom vang, but I added a makeshift boom vang by using MRS blocks and line. Connection point is same as for main sheet (as there is no other) but it seems to be able to do its job. But I still can't get the sail flatter than on the photo. You can really see lazyjacks interfering with sail shape too. Does it look normal to you, or is something wrong?
Mainsail tack is held by a pin on the boom. There is a hole similar to the one for the reefing but close to the reefing hook (whatever it's called) in normal unreefed sail position. Should I attach it to the hook or leave it free? I tried attaching it, not much difference...
How do I make the sail flatter? There is a slight mast bend, and mast rake, as I think there should be. Is there something wrong with my rigging or sail? Any way I can make it flatter? Or does it look normal to you?
BTW the mast bend is not as severe as on the first photo - it's the pincussion distortion from a cheap camera that makes it seem too curved. The real bend is maybe 1 to 2 inch difference between middle and top of the mast. When I raise the mast, after I pin the forestay with furler, I'm then able to pin the backstay by hand without huge effort, I shouldn't be able to create a too large mast bend just by pulling with my hand, I think.
