tlgeddes wrote:
....so I stared at that self releasing cleat and then went and stared at my boat.
I would have to see his in action to finish the visualization that I'm not getting to on my own.
However it seems like if I mount the cleat the opposite direction of what would be normal it would then serve the purpose of cleating the rope and releasing if the rudder kicks and and pulls the rope out of the cleat. Essentially it is rigged to hold the rope not keep the rudder down.
The cleat should hold the rudder
downhaul line. So a good thump on the rudder on it should pop it out.
tlgeddes wrote:Which leads me to a second question or thought. Why not have a cam cleat when pulling the rudders up and down?
That's what I installed. One cleat, two lines - one at a time. Hold rudder
up or holds rudder
down.
tlgeddes wrote: I am finding pulling the rudders up and adjusting them to be quite difficult using just the ropes even while the previous owner put pulleys on the rudder to allow for some additional mechanical advantage. Has anyone modified the rudder rigging in that way?
Yup. Several of us. A simple block on the trailing edge of the rudder provides a 2:1 advantage. Love it. I highly recommend it.
I've been trying draw up a diagram but it's not easy.
Here's a mod with photo:
http://www.macgregorsailors.com/modt/in ... ?view=1887
My variation on this uses only a single continuous line and ensures that I don't get confused between the uphaul grabby-part and the downhaul grabby-part.
Essentially, run the
downhaul part of the loop on the
outboard of your pushpit railing and run the
uphaul part of the loop on the
inboard side of the pushpit railing. There should be a loop in the cockpit that is always slack.
(So my mnemonic: down is outside, up is inside).
