Speaking of Autopilots...found this new remote
Spector
Location: Calgary AB, 98 26X 'Cenoté' 2002 Yamaha 60 HP
Post by Spector »
Found this the other day. No first hand eperience but just thought I'd put it out there for your thoughts
https://www.i3dgear.com/autobuddy
sailboatmike
Re: Speaking of Autopilots...found this new remote
Post by sailboatmike »
This is the bloke to see. he is a true sailor of Trailer boats who designed the unit and tested it.
Many many people are using his electronics now and I have never a bad word, in fact all I have heard is rave reviews.
http://www.madmanmarine.com/
stuendan
Post by stuendan »
Hi guys,
I'm using the Madmarine remote to control a Raymarine ST2000 attached to the rudder link bar. The down side with this setup is the lack of feedback (everything is below deck) - the Madmarine remote receiver does not provide an audible signal to verify operations, specifically auto/standby switching. Not a big deal given that the unit from 3D doesn't even allow going from auto back to standby from the remote!
ps. The physical connection to the rudder link bar is locked on/off by a solenoid driven indexing pin locating in a small slot cut into bar. When deselected, the link bar is free to slide through the connector. The "locking" solenoid is controlled via a switch on the side of the steering console.
Cheers all
[imgImageDSC_0211 by Stuart Baylis, on Flickr][/img]
sailboatmike
Im sure if you email him he will look into putting a beeper on the remote, thats the benefit of someone that does it for the love of it more than the $$$$ and has the flexibility that the big companies are not interested in offering
ris
Post by ris »
We went sailing with Flyboytr last October and he made his own remote for the autopilot. Was not pretty but cost less than $20. I think it used a garage door clicker and most components were housed in a 2X4 electrical outlet box. Maybe he will post and let you know how he did it
Seapup
Post by Seapup »
Awesome :!: Thats pretty slick. I have heard quite a few mentions of using the ST tillerpilots but that is the first install I have actually seen.
I have pondered electric gate openers since they look almost identical to a tillerpilot, made for outdoor use and even come with a remote.
For heading control I considered a lego ev3 robotics cpu and compass sensosr. They can be easily programmed to follow a compass heading and controlled via remote on bluetooth phone app.
Then spring always came and I went sailing instead 8)
Spector
Post by Spector »
stuendan wrote:Hi guys,
Bad idea from a safety standpoint. You shouldn't be able to disengage from the remote. This prevents accidental disengagement and ensures you're at the helm when its disengaged.
