Paul
I took the liberty of pasting your photo into AutoCAD and putting a photo of mine (taken fifteen minutes ago) right next to it. I rotated both photos a little so the boot stripes are horizontal, struck a line from the top of your mast to the bottom, and dropped in an angle dimension.* You can clearly see the bend in your mast, which scales to a little more than 4".**
I then copied the red line to my mast, and it lines up almost perfectly. I had pulled the main halyard very tight along the back (slot side) of the mast, and the red line sits right on top of it. Which tells me both masts are very close to the same amount of rake. FWIW.
This closeup is a bit grainy, but you can see the bend in the mast more clearly.
Mine has a little less, which scales to a little more than 2". Looks like mine could use a little more bend.
My upper side stays are tensioned to about 300 lb, and the lowers to about 270 lb, using the calibration I worked out using test weights. I'd have to decrease the lower tension a little to put more bend into the mast, and possibly increase the upper tension to compensate. But I've already taped up the pins and ringdings, and I'll go sailing (this week, I hope) with it the way it is. With my original, badly blown-out main, I don't think it's going to make much difference anyway.
*Angle from vertical is not what the manual says, but I measured 1-3/8" horizontal on 24" vertical with a framing square on the front of my mast, which is 3.3 degrees of rake. Using a heavy kellet off the main halyard, I got about 21.5" off-plumb, which is about 3.8 degrees of rake. But the little flat spot on the deck is tilted forward from level, so it's clear that angle from vertical is not the same thing.
**Scaling is a bit iffy, as the photos were taken from close-in and at ground level, so the horizontal measurement may be a little larger than reality.
