So this may be a little late, since you've already started building the new dashboard, but how do you use BOAT? How much electricity do you really need on each excursion? You said you don't have solar, and you live in sunny california, so I'm guessing you mostly just day-sail, maybe an overnight here or there. There are some (thinking YukonBob) who used to go out for four or five days at a time, without much certainty of sunshine for solar, or marinas to pull into. And they talked about having to be conscious of electrical usage, water usage, etc. Sumner going to the Bahamas...sure, you have to stay on top of things. Chinook and ris doing the loop probably have to watch everything. But for daysailing? For one night overnights (like what we do)? Nah... One battery is enuf. Small solar panel for charging in-between. Check the voltage, check the water...and take off. If we get to the point where the battery isn't lasting quite long enough for an overnight trip, then we'll do the equalization on it. Until then, I'm a sailor, not a battery mechanic.
(I'm not very OCD either, and some people are. So this is just an opinion, and all are entitled to be as anal about battery maintenance as they'd like...)
