Many thanks guys!
kadet wrote:How are you going to calibrate the st2000 below deck, as this cannot be done via seatalk i.e. via remote?
Good point, I'll have to pop below to do that on the unit itself. Although, as my own remote doesn't use SeaTalk, I could install a repeater of the little display on the binnacle but, for the rare occasions when calibration was needed, I don't think it would be worth the clutter.
stuendan wrote:The "only" downside with the setup is the lack of visual or audible feedback up top when going from Standby/Auto and vice versa. It's a case of hold the A or B button for 4 secs, then operate the +/- 10 deg inputs and see if the wheel responds (or not). Steering inputs (short A/B or C/D, for 1 deg or 10 deg course changes can be observed from wheel movements.
I agree, but I guess it's something you get used too; feedback in terms of response to commands should be pretty instant so...
stuendan wrote:Note that this remote will not allow rudder inputs in Standby mode, only Auto.
I just rechecked my st2000, both with the device's buttons and my £6 hard wired remote and they both steer the boat in standby mode.
I think the reason why Madman hasn't implemented this function (which isn't mentioned in the RM st2000 manual btw) is probably that his remote is designed for ALL RM autopilots and I'm guessing that some of them have a clutch mechanism that disconnects the drive when in standby.
I'm glad you mentioned it though stuendan; I may well end up settling for my own remote.
