Forestay attachment
- sailboatmike
Re: Forestay attachment
If you have a furler and leave the normal jib halyard in place it makes for a excellent backup forestay, I always keep mine attached to the push pit, just for extra piece of mind
DaveC426913
Yeah. I've heard that before. I should prolly do that.sailboatmike wrote:If you have a furler and leave the normal jib halyard in place it makes for a excellent backup forestay, I always keep mine attached to the push pit, just for extra piece of mind
C Buchs
I do this, but I have to make sure that I get the jib halyard really tight or it catches on the top of the furler.DaveC426913 wrote:Yeah. I've heard that before. I should prolly do that.sailboatmike wrote:If you have a furler and leave the normal jib halyard in place it makes for a excellent backup forestay, I always keep mine attached to the push pit, just for extra piece of mind
Jeff
DaveC426913
[quote="BOAT"]The forestay is always a scary place - but believe it or not there is actually very little actual force on the forestay - the boat is pulled through the water by the side stays and backstay (if you have one) but only 20 to 30% max - 70% of the force pulling the boat through the water comes from the mast base, mainsheet block, and jib sheets. (Pulling the mainsheet tight or the vang put's more stress on the forestay than the jib.[/quote]
I'm kinda concerned about lateral pull.
My forestay, when under full genoa, bends a foot or more to the side.
With the JOHNSON lever you set the in straight, with the ring taking no load, tape if necessary, then snap it closed after you have set it up right. Easy!
paul I
I can imagine. I installed a separate hound for the jib halyard about 18" or so above the forestay. Even then, the jib halyard has a tendency to slacken over time and will eventually foul the furler if the wind conditions are right. And of course, it always happens at the wrong time when you are trying to furl the genoa in. I keep the free end of the jib halyard tied to a cleat on the mast. It is not run aft to the cockpit because it is seldom needed (only for the MRS and for flying a spinnaker). When it does foul it requires me to either head forward and cleat the halyard tighter, or use a boat hook to grab it at the mast and pull to apply tension to keep it out of the way when furling. It has only happened to me twice, but that's twice too many.C Buchs wrote:I do this, but I have to make sure that I get the jib halyard really tight or it catches on the top of the furler.DaveC426913 wrote:Yeah. I've heard that before. I should prolly do that.sailboatmike wrote:If you have a furler and leave the normal jib halyard in place it makes for a excellent backup forestay, I always keep mine attached to the push pit, just for extra piece of mind
Jeff
Without the extra separation the second hound provides between the halyard from the furler, I'll bet it can become an even bigger issue that happens more frequently.
C Buchs
My jib halyard is connected to the mast at the same location as my furler. I thought about moving it up, but not seriously until now. I checked BWY and it looks like I need to add this to my next order. http://shop.bwyachts.com/product-p/3807-1v4.htm Thanks for the tip.paul I wrote:
Jeff
The only way to fly (a kite).C Buchs wrote:My jib halyard is connected to the mast at the same location as my furler. I thought about moving it up, but not seriously until now. I checked BWY and it looks like I need to add this to my next order. http://shop.bwyachts.com/product-p/3807-1v4.htm Thanks for the tip.paul I wrote:
Jeff
Note that the inboard part of the spin halyard should be inside the lower hound. I must have just put the hardware on and didn't realize the line would foul the jib hound.
paul I
You can also buy just the hound assembly if you don't need a new block. Its less money and it allows you choose the block you want.C Buchs wrote:My jib halyard is connected to the mast at the same location as my furler. I thought about moving it up, but not seriously until now. I checked BWY and it looks like I need to add this to my next order. http://shop.bwyachts.com/product-p/3807-1v4.htm Thanks for the tip.paul I wrote:
Jeff
