I need to replace my faucet in my 2008 26M
Has anybody any positive or negative experience (i.e. leaking or not holding prime) with the replacement sold by BWY?
RV replacement pump aprox $40 cnd or Whale gusher pump $100. Whale is nicer with more flow, smoother etc but it’s up to you as to whether it’s worth twice the price
Highlander wrote:Gezz Guy,s
I can,t remember when I used mine last I usually just have a 2 gal jug of water on the counter !
Some of us have converted our counter tops. I can still use the cutting board as a counter, but would prefer not placing a 16.6lb (7.5Kg) weight on it. Under the sink is a fine location for the 5 gallon container. In these photos I have not yet hooked up the OEM hand pump faucet.
I use the Jabsco faucet. I bought an ATV Sprayer for about $50. Came with a pump, then I bought the faucet separately from ebay for about $30.00. Normally the faucet comes with a pump which bumps the price up to $130.00 but you can find the faucet separately for much less. Here are some links.
I installed the tank in the bow after I pulled out some floatation foam. Not too worried about losing flotation as the tank is sealed and provides a separate amount of floatation. (empty of course). The Jabsco faucet turns the pump on and off. If you were to use a regular faucet, once the Ironton pump is pressurized, it shuts off automatically. So it gives you two different options for how you want to do your plumbing, a pressured system or on/off pumping.
Ray Quote
5 gallons R U Bathing in ur sink ! is that why u had to get a bigger one ?
PS nice work when r u coming over to do mine Eh!
Highlander wrote:Ray Quote
It’s actually a smaller sink. It’s a bar sink. I bet that gets your attention John
I got the idea (and some detailed info.) from fellow board member, RIS.
I installed an electric pump that stops when the pressure rises.
And a faucet that switches off the pump when turned off.
Yes you use mor water. I allready bought a switch to turn on with the knee but didnt installed yet. Too lazy.
If water consumption is a problem evetually I would put 1 liter in a botle an then rins my hands...
