26x Boom during a bridge crossing.
randall330
Post by randall330 »
I have the mast lowering system and it works great. The question is to lower the mast to about a 45 deg. angle to pass beneath a bridge should I remove the boom or just let it ride in the cradle? Any thoughts would be appreciated.
Alexis
Re: 26x Boom during a bridge crossing.
Post by Alexis »
Sounds like an unnecessary step, but I am guessing It would need to be secured somehow ... So maybe removing it would just be as complicated (or simple depending your point of view).
Or you can do this: https://www.youtube.com/watch?v=m_7Yg4b6TSk :wink:
Signaleer
Location: Foley, Alabama...2002 26x & 2002 90 HP Mercury Salt Water 2-stroke
Post by Signaleer »
You can lower the entire rig with the boom attached.
putting it in the cradle will be fine.
Seapup
Post by Seapup »
Be careful, the mast is very unstable at 45deg. Its a bit safer to lower it the whole way and then raise it again. I did the halfway once for a bridge, every time after it was the whole way down.
Spector
Location: Calgary AB, 98 26X 'Cenoté' 2002 Yamaha 60 HP
Post by Spector »
Just make sure the sliding companionway cover is closed. Otherwise things can go crunch. I angle the boom off to one side as its coming down too.
Post by K9Kampers »
...and be mindful of the backstay so it doesn't get tangled in the prop!
