I'm not familiar with the X's layout so hopefully someone else will jump in.macowneril2015 wrote:Ok, Thank you. I have an old fuse panel replacement, so would it benefit me to upgrade it or just move forward with it? I was planning on setting up / installing shore power at some point this summer. I also plan on in the immediate period installing a charger and from my take away a combiner since I plan on having 2 batteries. Also any suggestions on dual purpose batteries / places to buy them (Walmart, online ... etc)
I'm a big fan of running two 6 volt golf cart batteries in series and have 6v Trojan T105's in both boats. I needed two 12 volt batteries in series also for the Mac for a trolling motor and went with Deka 12 volts after doing some research. You don't need dual purpose, even the 6 volt batteries in series will start your outboard. The Trojan's are 'true' deep cycle. Most 12 volt batteries that say they are 'deep cycle' aren't 'true' deep cycle.....
http://www.pbase.com/mainecruising/deep_cycle_battery
.... but that is what you will have to settle for if you go with two 12v batteries,
Sumner
The MacGregor 26-S
The Endeavour 37
Mac-Venture Links
