Helm Seat Cracking on 2008 26M
- Darrin Stubbs
My helm seat is starting to crack where the corner sits flush with the starboard side cockpit bench. Does anyone have any great suggestions for a fix before it gets out of hand and requires a full replacement.
I do have lots of good pictures of it but I can't figure out how to post them on this forum? It doesn't seem as simple as attaching a pic file?
http://tinypic.com/usermedia.php?uo=NuV ... h4l5k2TGxc
- kurz
Re: Helm Seat Cracking on 2008 26M
My helm seat cracket at the port side. So renew it as long as the side that locks inside the cockpit stays ok.
I fiexed it by glassing it at the side that loocks to the motor. As it is much stronger now it stays ok.
- dlandersson
Have you considered having someone go on a diet?
Darrin Stubbs wrote:My helm seat is starting to crack where the corner sits flush with the starboard side cockpit bench. Does anyone have any great suggestions for a fix before it gets out of hand and requires a full replacement.
Darrin,
There are photo storage sites that you can use to store and send photos from. I use tinypics. In tiny pics, you select the photo you wish to show in your posting. Then you select “copy one link” so as to paste it to your MacGregorsailors posting.
- Darrin Stubbs
lol Funny guy!dlandersson wrote:Have you considered having someone go on a diet?![]()
- Darrin Stubbs
NiceAft wrote:Darrin,
Awesome news Ray! Thank you. I'll give that a try.
Darrin
Darrin
I'm thinking some fiberglass repair kit would do the job. I'm not an expert and don't know what reinforcement might be required.
Posting photos is easy
on you tinypic account copy the second link with the IMG Code for Forums & Message Boards
Then paste it into here.
Like this
Like this
- Darrin Stubbs
Ahhhhh...Like this?RussMT wrote:Darrin
Like this
I did mine last spring...I had thought I had cracked it due to being really clumsy...turned out it had been cracked previously and bondo'ed over (don't do that). It is a really easy fix. Just get some fibre mat..use a couple or three layers worked into the resin, making sure you turn the 2nd on 180 degrees from the first for added strength. Let it dry, sand it, finish it however you want. My seems super-strong now.
- Divecoz
I have caused / allowed damage to the Transom seat by allowing it to slam shut from a fully open position.. That said , its not as apparent as yours is.
I Hope that,s not in reference to ur last name !Darrin Stubbs wrote:lol Funny guy!dlandersson wrote:Have you considered having someone go on a diet?![]()
- Don T
Hello,
Isn't that what the cable is for? Holds the seat down and gets clipped onto the lifeline to hold the seat open.
- Darrin Stubbs
Makes sense....Makes good sense...Don T wrote:Hello,
Cantcha jus move the location of yer cockpit bar?! Jus sayin'...Highlander wrote:...don,t know how many times it,s almost decapitated me when my heads been down there !
Oh boy John, he knows you.K9Kampers wrote:Cantcha jus move the location of yer cockpit bar?! Jus sayin'...Highlander wrote:...don,t know how many times it,s almost decapitated me when my heads been down there !
