De-powering to 10-25 hp ob motor?
Anyone running a lower 10-25 hp ob motor? If yes, what is your experience?
My Evinrude E-tec just fried. EMM (onboard computer) destroyed. Spark plugs completely black. $2500 repair bill. My dealer suspects the cause may be due to excessive low rpm usage. We just don't run our boat at plane much.
Therefore, it may be more suitable for my next motor to have just enough power for full displacement mode + a little extra in reserve for super windy days and power through squalls.
Some of us owners may have installed 10 hp motors. But my mechanic is concerned that 10 hp may be insufficient. I just wish to learn from you your experience. Any recommendations or regrets?
Re: De-powering to 10-25 hp ob motor?
I have been running a 25 hp. since I purchased my boat 3 years ago, PO installed. I can run for two days on 6 gallons of gas. Top speed is about 10 knots with ballast empty. I never empty the ballast and I can still run at 8 knots with about 3/4 throttle. I have an older 3 cylinder Suzuki which I would not recommend as it is a bit loud. Additionally the motor did not come with a power tilt so I added an after-market. I this motor ever fails on me I don't think I would increase to a larger motor as this does great for us, and fuel consumption is great compared to others I have talked to. Plus it is easier to get on and off with the smaller foot print.
Bob
Bob
I've had a 50 hp Honda on my boat and switched to a 30 hp Yamaha when it was stolen.
Personally the 30 hp is ok, but with family the 50 hp was much better. We could get to distant anchorages much quicker, the ride was more entertaining for the kids and overall they enjoyed it much more.
The 30 hp runs at approx. 10 knots, but is then really working hard, so I do not like that. I'd rather go slower at 5-7 knots which is really nice with that motor as you hardly hear it, but the kids start to complain quickly because they get bored.
So, it depends.
So, it depends.
I ran a honda 50 for a few years, then suzuki 90 for a few and then suzuki 20 on myTherefore, it may be more suitable for my next motor to have just enough power for full displacement mode + a little extra in reserve for super windy days and power through squalls.
I bought the suzuki because at the time it was relatively cheap and 300cc fuel injected vs 200ccc carburated for the rest in that class. Tohatsu now has a similar fuel injected 333cc 9.9 with 12a alternator that looks pretty nice. I have had a few yamaha high thrust 9.9s and they are definitely my favorite for a displacement hull, but cost around 3k vs 2k.
beechkingd
Which trim unit did you go with?bobflshmn wrote: ↑Tue Aug 20, 2019 9:37 am I have been running a 25 hp. since I purchased my boat 3 years ago, PO installed. I can run for two days on 6 gallons of gas. Top speed is about 10 knots with ballast empty. I never empty the ballast and I can still run at 8 knots with about 3/4 throttle. I have an older 3 cylinder Suzuki which I would not recommend as it is a bit loud. Additionally the motor did not come with a power tilt so I added an after-market. I this motor ever fails on me I don't think I would increase to a larger motor as this does great for us, and fuel consumption is great compared to others I have talked to. Plus it is easier to get on and off with the smaller foot print.
Bob
SolarSailor6
I run a 9.9 hp Yamaha 4 stroke long shaft high torque engine with "power prop". I can achieve hull "displacement speed" on my MacX of about 6.4 mph on 1/3 throttle. 10 mpg on average or 0.5 gallons per hour at that RPM Setting with water ballast full.
If you are not in a hurry, you can do 50 mile days with ease.
Ken
Lexington, KY
Ken
Lexington, KY
- opie
This topic is interesting since my 1999 Honda BF50A is getting old.
The admiral enjoys going about 6 kts. She says she gets to see more things....
One question: We have inlets with swift currents at peak times, maybe 4 kts.
What is max speed of 9.9 hp? Of 25 hp?
thanks.
thanks.
I went with the CMC PT35 from Cabels. Was on sale at the time I purchased it with free shipping. I have had it two years and it has worked great.beechkingd wrote: ↑Fri Aug 23, 2019 10:03 amWhich trim unit did you go with?bobflshmn wrote: ↑Tue Aug 20, 2019 9:37 am I have been running a 25 hp. since I purchased my boat 3 years ago, PO installed. I can run for two days on 6 gallons of gas. Top speed is about 10 knots with ballast empty. I never empty the ballast and I can still run at 8 knots with about 3/4 throttle. I have an older 3 cylinder Suzuki which I would not recommend as it is a bit loud. Additionally the motor did not come with a power tilt so I added an after-market. I this motor ever fails on me I don't think I would increase to a larger motor as this does great for us, and fuel consumption is great compared to others I have talked to. Plus it is easier to get on and off with the smaller foot print.
Bob
Alexis
Hi,
My 1996 Mac 26X came with an old 9.9 2-stroke Nissan. I sail my boat on a lake, which sometimes have pretty strong winds and short waves, but no swell of course.
I am quite happy with the OB. It pushes the boat at hull speed and has enough power for my needs. I like the extreme simplicity of the engine: its maintenance and winterization are almost non-existent, this means more time on the water!
Downsides are: it is very noisy, and it isn't very practical (no power tilt nor electric starter) but it is light enough and I don't mind having to open the helm seat.
If you don't need to go fast, a smaller engine offers a tremendous economy (these things are expensive!). 9.9 is on the lower side, if I had to change my engine I would get a 15 minimum and no more than 25. The 25 - 45hp range doesn't make sense IMHO because you need at least 50 to plane the hull and may be overpowered for hull speed.
The 9.9 on my Aquarius was adequate for reasonably calm conditions, but not enough when pounding through waves and wind. It was a displacement hull, but that didn't matter as waves would stop it in its tracks. More thrust would have been nice to get going again after hitting the wall (wave) repeatedly. Very hard to make progress.Alexis wrote: ↑Mon Aug 26, 2019 12:23 pmIf you don't need to go fast, a smaller engine offers a tremendous economy (these things are expensive!). 9.9 is on the lower side, if I had to change my engine I would get a 15 minimum and no more than 25. The 25 - 45hp range doesn't make sense IMHO because you need at least 50 to plane the hull and may be overpowered for hull speed.
I also agree that much more than 15 hp would be a waste, as you need a lot of thrust to get the bow up high enough to semi-plane. A 25 would likely, IMO at least, just put the bow high and burn more gas but barely go any faster. That transitional speed where steering is lousy and you're just plowing a big wake while draining the gas tank at a goodly clip.
- mallardjusted
- Location: Puget Sound, 2001 Sold Oct2021 "Aqua Dawg", 70hp Yam
I can do hull speed extremely economically with my Yamaha 70 (and it only weighs about 10 lbs more than a 50). But I can also do 23mpg if I want to. My kicker is a 9.9hp Mercury, and can push the boat at or near hull speed. But with some currents and winds, I don't think I personally would go below a 15 for a main engine.
- dlandersson
Ditto.
mallardjusted wrote: ↑Sat Aug 31, 2019 11:00 am I can do hull speed extremely economically with my Yamaha 70 (and it only weighs about 10 lbs more than a 50). But I can also do 23mpg if I want to. My kicker is a 9.9hp Mercury, and can push the boat at or near hull speed. But with some currents and winds, I don't think I personally would go below a 15 for a main engine.
Snowdancer
25 hp high thrust older Yamaha with 12.25 x 11? Prop will get boat up to 13 mph and allow planing and pulling a tethered wake surfer behind 26X.
Don't buy a new Yamaha T25C it vibrates terribly and transmits throughout the boat plus it's smaller prop barely achieves a plane with 4 adults and coolers in waves. Max speed under 10 mph.
Not much quieter than old 50 hp tohatsu but substantially better on gas about 6 miles per gallon versus 1.2
- Herschel
When my Merc 50 h.p. died back in 2013, I was faced with a similar quandary. I finally decided to replace it with a 50 h.p. Yamaha. I figured it was good to keep the boat capable of doing what it was designed to do regardless of my usage pattern as that might change over time. Plus, it would keep my resale value at the appropriate level. I keep my boat in a marina slip on the St. Johns River system in Florida so there is a lot of opportunity for cruising by engine and sailing on the lakes. I decided that part of my hesitation was just the shock of the cost of the 50 h.p. engine and that was like anything that breaks and the replacement cost is not currently in the budget. As I type this, I am anticipating replacing my home air conditioning system next Tuesday at a $5K level of expense. Ouch! But, once you adjust to the "new" reality and make plans for the expense, it works out. I am glad I stayed with the 50 h.p. engine. If for no other reason, I have bragging rights with my Hunter 26 marina mates.
No, seriously, I do enjoy the power cruising down river. We have a railroad bridge to pass through and sometimes they need me to crank it on so I can squeeze in between trains.
- Dimitri-2000X-Tampa
What happened to your 50 to kill it? I brought my 20 year old Merc back to life by replacing the CDI (ignition) unit last year and have been trying to decide in my mind what constitutes a 'replace' event. I have eyed the Merc 60HP big foot as the replacement as it is the same size and weight as what I have now but with 10 HP more (no weight and size penalty but does cost about 400 bucks more than the 50).
And talking about A/C units, I was disappointed when my 17 year old 2-stage Trane unit got an unfixable leak a couple years ago and had to be replaced. The older ones seemed to last longer so I replaced the Trane with a simpler (and cheaper) 1-stage Bryant/Carrier unit.
