I recently dropped out my centerboard and removed my rudders, sanded them down, and painted on some Interprotect2000E followed by several coats of VC-17 smooth anti-fouling paint. I posted about that adventure on another thread.
Now I'm moving on to removing the existing anti-fouling, which is at least a dozen years old. My boat already has a layer of grey Interprotect2000, also a dozen or so years old.
Sanding off the existing anti-fouling is a nightmare. There is a layer of greenish grey freshwater slime over the anti-fouling that powders up right away, then I have to work through a still-thick layer of light red powdery anti-fouling, then a thin layer of dark red hard anti-fouling before I reach the Interprotect. Once at the Interprotect layer, it is really hard to sand away all the anti-fouling. The Interprotect tech data says to apply the first coat of anti-foul while the last layer of Interprotect is still tacky. I guess that's how they did it, because the bond is amazing. Using 80 grit with a hand-sander, it is just so darn hard to get all the little red flecks removed.
Here's a photo of my progress:
You can see each layer: dried slime, light red powdery anti-fouling, dark-red bonded anti-fouling, grey interprotect. The dark red stuff is just about impossible to get off.
Couple of questions...
Is 80 grit followed by 180 grit the right plan of attack?
What if I don't get all of the small red flecks off before I re-coat with Interprotect? How much leftover red is ok?
There are a few good scratches and chips underneath the boat. Interprotect 2000E tech data says you can fill scratches with it, not sure if I should just overcoat a bunch of times or buy something else to fill them first?
Here's a photo of about the best I can do without sanding all the way through the old Interprotect layer:
It's not in great focus. It shows the scratches created by the 80-grit, this photo was before the 180 grit.
This is HARD. I've just about finished sanding the front half of the boat to the end of the centerboard trunk, still the entire bottom half to go. Blah. But I got nothing else to do so I'll just suck it up.
