A tighter cover can increase rust by trapping moisture but a loose bucket should be OK.
I'm about to do a search here; guess I can ask too - anyone have a wiring diagram for the 26X?
The engine starts and the tilt and trim works... And that is it. Absolutely nothing else electrical works.
Maybe the light on the mast works, when it is plugged in? Dunno, I still have not even attempted to raise the mast.
I've ordered 50 ft of tinned marine wire, both black and red. Probably not enough but it's a start
I think I pretty much need to rewire the whole thing but it would help to know how it's supposed to be wired!
I recall reading the original wiring was never great and not proper marine wire? Knowing the circuit and routing would help a lot though.
The PO has fitted 2 batteries, far away from each other. My understanding is that the original design is a single battery next to the galley? I have a battery selection switch and would like to set 2 batteries in that location but I'm not at all sure how to wire it so that the engine can charge both etc.
It also has 2 ventilation fans, blowing from the head and galley to the cockpit, plus an electric toilet. There's a light above the table and another above where the stove would be, if I had one. None of these work at present. There's a whole bunch of wires in the toilet cupboard thing, no idea what they are.
I could do with an electrician but you know, the Borneo thing
