He’s also one of the most interesting people you’ll ever meet. I’ve had the pleasure of sailing and hanging out with him and a few others from this board up in the Toronto area for a few years (the MMOR rendezvous), though he’s waaaay over on the left coast as of a couple of years ago.
hauling with mast stepped but lowered
Re: hauling with mast stepped but lowered
Tom
Be seeing you . . .
Be seeing you . . .
leefrankpierce
Seems there is a story on the forum about someone having portlights in the side and sinking their boat when one opened, presumably when heeled far to that side.I always wondered how close to the water we get our rub-rails.
Worried about the mast mounting point, it is not designed to resist up pressures.
I can imagine someone in a Cabover not seeing the mast and getting the mast through the windshield.
Pulling with a Mini-Van?
My 4-WD 1500 suburban has a hard enough time keeping the rig under control, never bought into the adds using a car to tow.
I do like the 2 axle trailer, possibly that helps enough.
Slip at Eagle Mountain Lake
- Ixneigh
Concur with others this is a bad idea, although comforting to know that the mast base is far more robust that I gave it credit for
Ix
Ix
"Shoal Idea"
2011 M, white
Tohatsu 20
South Fl.
2011 M, white
Tohatsu 20
South Fl.
- PhysicsTeacher
- Location: Abbotsford, BC, Canada 1999 26X, 60 HP Yamaha
A few years ago I was at Harrison Lake (in British Columbia) getting ready to rig my
. Suddenly a vehicle towing an
pulled up next to me with his mast in the same position as the original poster mentioned.
The owner lived about 2 blocks from the boat ramp, and always trailered his boat that way. In addition, he had a back injury, so he was unable to raise the mast. Instead, he had an electric winch on his trailer. He attached the winch to the mast in the same location as the mast-raising system, hopped back onto the ground, and . . . bbzzzppt, up rose the mast, perfectly in place. He pinned his furler to the foredeck, and drove down the ramp to launch, about 10 minutes after his arrival.
I have to admit, his setup was pretty slick.
Kelvin
Bonus: I got into the water around 45 minutes later, and then I caught up to him on the lake. He was having motor issues and could only go in reverse. So, after all that, I reached our destination about 30 minutes before he did.
Kelvin
No trees were killed to send this message, but a large number of electrons were terribly inconvenienced.
DaveC426913
In my case, it was a very built up area in megacity Toronto. Nevermind the risk to the mast - I can't see how this guy even cornered without taking out a condo or two.
Oh. Did I forget to mention that the whole neighborhood is laced with high voltage overhead streetcar power lines?
MacX 2000 Honda BF50A 'SeaSaw'
