I,ve ordered this cam with solar panel
https://www.bestbuy.ca/en-ca/product/re ... lsrc=aw.ds
I thought about mounting this up the mast say 1/2 way up but I think I might have to turn down the motion & infered sensing so low as not to cause false signals "think about how much the mast sways with other boat wake & windy conditions" these sensors r going to b sending out false alarms like crazy not good but as I already have a security cam in the cockpit sensing I could just turn the sensing of on the mast cam & if the alarm sounds off I still have the option of live viewing either cam or both
but I may try mounting it on my radar arch as long as it doe,s not cause any interference to my AIS, VHF, TV , cell ph booster marine antennas & GPS/radar signals
I,ll also b installing a 128gb mini sd card into that new cam as when the sd gets full it will auto
Now for u who r not frugal like me & have the big $$$ u can buy this cam on sale & install a sim card with data plan & eliminate the need for a cell ph as it,s it,s own hotspot
https://www.bestbuy.ca/en-ca/product/re ... r=PDP_Reco
these r Can$ prices so likely cheaper on the USA side
I would not buy a cam that is 5GHz wifi unless it has dual band width & here,s some interesting reading as to why !
https://www.centurylink.com/home/help/i ... u-use.html
some of the newer cell ph,s have dual band width but for the purpose of this set up U,ll likely just b using an old cell ph u were no longer using as I & Russ did
more info on setting PIR motion sensors
https://support.reolink.com/hc/en-us/ar ... -PIR-Angle
Also I keep my old cell ph hidden outa site on the boat because if someone is still brazen enough to keep trying to break into my boat after the spot light comes on "night time " infered turns on night time vision if needed & is heat sensitive so picks up body heat, but some guys may have a mask on to cover up their identity likely not gonna happen on our boats lol maybe a mega yacht
but I figure if he gets into my boat no point in giving him acess to turn off my cell ph hot spot
so u have to make sure where ever u hide the ph it,s not blocking the cam connection to the ph I figured out about 10 great spots but only 3 or these would allow connectivity due to s/s tubing, riigging hardware, other electronics too close or LED lights in cabin when turned !
so u have to make sure by live viewing that u can make that connection from the dock on ur main cell ph u may think I,m rambling on but believe me this will save u a lot of headaches not having to go thru these trying moments "what did I do wrong"
for an IT guy he,s likely
but an average guy like me it can b time consuming
Oh yeah if their,s any app,s running on that old cell ph u don,t need turn them off or uninstall them as they r eating up ur data & running down ur cell ph battery time span life & continous opperating time
hope this helps
