All good feedback and concerns which I will respond to.
craiglaforce: By the time the carb cleaner is in the cylinders, it is finely atomized as a fuel/air mixture which I strongly believe wouldn't be capable to remove the oil coating from the metal surfaces. Also due to some residual gasoline in the fuel line, it's never probably at 100% anyhow. Lastly, the engine is run at a no load condition during the entire process which doesn't last that long to begin with.
SJB: I'm curious why you would think it would explode? I'm just substituting once fuel source for another in its existing metering device that just has higher oxygen content. It's not like I'm haphazardly dumping the carb cleaner down the carbs or using nitro-methane!
FWIW, if you go and pay $50-$100 for a fuel injection cleaning at your local monkey garage, they will disconnect the fuel rails from the gasline and inject a carb cleaner type of solution into the fuel injection system and run the engine, very similar to what I propose here. However, they will use a cleaner that lacks methanol as that harms catalytic converters.
dennisdl: No smoke or anything and the engine ran like normal once I slightly put the choke on to compensate for the lean burn from the oxygenated fuel. However, the exhaust odor was slightly different hinting to the carb cleaner being burnt inside of the engine. I made sure the choke was not overdone here though as you don't want to dump raw carb cleaner solution into the cylinders for the reasons that craiglaforce mentioned above.
John Mc.: I don't think any or a very small indetectable amount of the carb cleaner (the Berryman B12 stuff can also be used as the crankcase engine cleaner too) made it into the oil since this is done with a small amount of cleaner relative to the hundred+ gallons of gas that is run through the engine between oil changes. The little bit that might have made it would probably evaporate anyhow by the time the oil came up to operating temperature due to the higher vapor pressure of acetone and some of the other components. In your case, you physically dumped a significant amount of the cleaner into the crankcase, and I'm sorry to hear about your demise. Today, I test ran the engine again and it felt strong like yesterday. Also, I just change the oil last week with fresh Mobil1 5W30 full synthetic. I pulled the dipstick and everything looked and smelled normal. I finished up the maintenance by synching the carbs and once I get a lower pitched prop, I will try again to see what my Mac19 is capable of.
Overall, I feel I'm an accomplished mechanic and that this procedure could be beneficial for certain people if done correctly. It defininitely worked for me. However, if you're risk averse and/or don't even know what a "Vise grips" is, I would suggest for you to pony over the $500 or so and have your Honda dealer rebuild the carbs. In addition, I agree that 2-stroke owners should NOT utilize this process.
-Chris
